ANYONE KNOW WHAT THE RECESSED BUTTON OR SENSOR OR WHATEVER IS ABOVE THE RIGHT DASH BUTTONS... i AM TALKING ABOUT THE ONE WITH TRIP AND OPTIONS. I NOTICED A RECESSED HOLE ABOVE THEM THEM AND WAS WONDERING WHAT IT IS....
ALSO HOW DO YOU REPLACE THE REAR VIEW MIRRIR LIGHTS ON A 2002 I SEE THE LENSE BUT CANT FIGURE OUT HOW TO GET THEM OUT.. AND I ALREADY HAVE THE REPLACEMENT BULBS....
THANKS
BRIAN
P.S. HAVING THE GAS GAUGE PROBLEMS NOW !!!!! GREAT
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Originally Posted by aredneckforu
HEY EVERYONE
It is a light sensor for the few items on the dash and for the light on the radio and Climate control unit. Place your finger over the button and you will see the MPH or KPH get diimmer or brighter.
1] Remove the lamp lens from the mirror housing. Pry carefully with a small, flat-bladed screwdriver (at the rear edge (1) of the lens, furthest from the windshield).
2] Remove the bulb from the socket.
Installation Procedure
1] Install the bulb into the socket.
2] Install the lamp lens to the mirror housing. Insert the forward edge of the lens (1) (the edge nearest to the windshield) into place and push up the rear edge to snap in place.
Patches I would really appreciate seeing how the entire rear view mirror is removed. . . . I think I know how but my guts are not sure it looks like you get a small blade screwdriver and pry on the twin tabs near the windshield and pull back on the mirror.... really would like to see what the pictoral says
thanks
If your mirror is the self dimming, it will not have the set screw to remove. It is locked in by those two tabs you mentioned.
I just removed mine a while back and the instructions in the manual are not very good. I have heard of quite a few windshields de-laminating around the mirror when the factory manual is followed.
The best way is to get a small, round-jawed vice grip that will span both of those locking tabs on the mirror mount. The locking tabs are part of the mirror and will come off with the mirror as one unit. Simply adjust the vice grip so that it will lock onto the 2 locking tabs and the bottom of the mirror. You want to lock the tabs down so that the mirror will slide off of the windshield mount.
