Coolant Change
Old Aug 7, 2004 | 01:18 AM
GrayC5's Avatar
GrayC5
Yes, I would follow the manual and change it too.
Old Aug 7, 2004 | 03:30 AM
Shylor's Avatar
Shylor
It's not cheap insurance if it doesn't need to be changed. Just follow the owners manual. If clumping of the coolant is noticed in your overflow tank then change it sooner.
Old Aug 7, 2004 | 07:50 AM
TomT's Avatar
TomT
There are several service bulletins about Dexcool and the change interval. Apparently some people have had the Dexcool breakdown and deposit crud in the cooling system, causing overheating and damage to the system components, well before the service interval.
i.e. Change it.
Good luck.
Old Aug 7, 2004 | 11:01 AM
Shylor's Avatar
Shylor
If you read the bulletins correctly you would know those people also either mixed dexcool with another type coolant or already had contamination in their cooling system which started the crud in their dexcool. It was not because the dexcool broke down early on its own.
Just watch the overflow tank and you will be okay.
Old Aug 7, 2004 | 08:35 PM
Autoworker's Avatar
Autoworker
Consider it "Corvette Love" and go ahead and change it.
Old Aug 7, 2004 | 09:38 PM
GrandSportRob's Avatar
GrandSportRob
It's been 5 years, change it....
