Air Dam Removal
Old Aug 6, 2004 | 06:38 PM
DirteeDave's Avatar
DirteeDave
Default Air Dam Removal
Just wondering what the downside to removing the air dam would be. It scrapes every time I back out of my driveway and its starting to drive me nuts. Have any of you done this?
Old Aug 6, 2004 | 07:28 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Reduced cooling efficiency.
Old Aug 6, 2004 | 07:45 PM
C5inWV's Avatar
C5inWV
Your engine will run a lot hotter without it. Change your driveway if you have to, but leave the dam on.
Old Aug 6, 2004 | 07:51 PM
The air flow to your radiator will be disrupted. The air dams are relatively easy and inexpensive to replace. I would leave it on and once it gets to looking really crummy, just replace it.
Old Aug 6, 2004 | 08:15 PM
pk2401's Avatar
pk2401
St. Jude Contributor
I think I read somewhere that it is there for better cooling and helps stablize the car under high speeds.
Old Aug 6, 2004 | 08:32 PM
jfrc's Avatar
jfrc
i use it as my clearance gauge, kinda like a curb feeler for beneath the car if you will
Old Aug 6, 2004 | 08:47 PM
jerrymcb's Avatar
jerrymcb
It also lowers your coefficent of drag. It is designed to scrape,
the center section pivots to fold back if need be, and they are
Old Aug 6, 2004 | 10:53 PM
DirteeDave's Avatar
DirteeDave
Thanks guys, looks like I'll be leaving on.
Old Aug 7, 2004 | 01:38 AM
golfman2008's Avatar
golfman2008
St. Jude Donor '05
Why go through all the scraping and investments when there is a better sytem called the Big Mouth Air Dam , improved CFM , improved cooling to all your coolers and performance ! And the best part you can enjoy driving without the scaping check it out
C4orceCorvette.com
Here is a picture of the install with frame Savers as well , thanks
Old Aug 7, 2004 | 02:17 AM
Shylor's Avatar
Shylor
Yes if you really want to remove your front air dam then I would install the big mouth.
Old Aug 7, 2004 | 08:08 AM
tT-REXXX's Avatar
tT-REXXX
Default water
I :I would be afraid of ingesting water into the engine from a small puddle. Thats another funtion of the airdam ya think!
Old Aug 7, 2004 | 08:31 AM
golfman2008
St. Jude Donor '05
Not at all , its completely the oppssite effect ! The Big Mouth seals that area off from picking up road trash or water and because of its shape and position ( there is no terbulance ). Plus now its 1.5 feet away from the front tires ( no splash ).
Old Aug 7, 2004 | 10:58 AM
Shylor's Avatar
Shylor
How do you figure that? The stock air dam does the same thing only on a larger scale. The big mouth is smaller but more focused and is not pointing as much at the ground, like the center air dam is.
Old Aug 7, 2004 | 12:30 PM
golfman2008
St. Jude Donor '05
Default yes , yes ! it looks very clean
Here ! here !
To Air Dam Removal
