I want to put the sub and the stealth box in my Z06 and i was wondering if that affected the drivabilaty of the car since the Z06 is made to be light and then i would be adding like 50 pounds of sub and wood in the back behind the tires. Any input please!!
Jimmy
It depends on what do you wanna do with your car. I have sub on mine and its no big deal. What is a few lbs. if you want a nice sounds. If you worried about the weights, its your choice.
Adding a box will not be extemely noticable since it can not be big. I am sure some will notice a difference. To me it is worth the added weight. I went with 2 10's and replaced my head unit and my factory speakers.
Jimmy
It's not only static weight but where that weight is located, the passenger is located in a very good spot, your sub and amp will be in the extreme rear of the car. I was thinking of doing what you're doing and I was going to make the sub and amp removable for auto-x etc.
FYI: I got my box from Mike who frequents the board. Top notch and a pleasure to deal with. Here is a link to his page http://www.geocities.com/mikec5vert/
Mikes not making boxes anymore. Maybe around nov. he said.
