Vortex / Warranty Question
Old Aug 8, 2004 | 12:57 PM
keyscat's Avatar
keyscat
Default Vortex / Warranty Question
Will the installation of the Vortex Rammer void the warranty on a new vette?
Thanks for your response
Keyscat
Old Aug 8, 2004 | 01:12 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
I would be more worried about the standing water down there in Key West than the General but below is some interesting reading
Warranty Admin. - Non-GM Parts and Accessories (Aftermarket) #04-06-04-054 - (Jul 28, 2004)
2005 and Prior Passenger Cars and Trucks
2005 and Prior HUMMER H2
The recent rise and expansion of companies selling non-GM parts and accessories has made it necessary to issue this reminder to dealers regarding GM's policy on the use and installation of these components.
When a dealer is performing a repair under the New Vehicle Limited Warranty, they are required to use only genuine GM or GM-approved parts and accessories. This applies to all warranty repairs, special policy repairs or any repairs paid for by GM. Parts and accessories advertised as being "the same" as parts manufactured by GM, but not sold through GM, do not qualify for use in warranty repairs, special policy repairs or any repairs paid for by GM.
During a warranty repair, if a GM original equipment part is not available through GMSPO, ACDelco® distributors, other GM dealers or approved sources, the dealer is to obtain comparable, non-GM parts and clearly indicate, in detail, on the repair order the circumstances surrounding why non-GM parts were used. The dealer must give customers written notice, prior to the sale or service, that such parts or accessories are not marketed or warranted by General Motors.
It should also be noted that dealers modifying new vehicles and installing equipment, parts and accessories obtained from sources not authorized by GM are responsible for complying with the National Traffic and Motor Vehicle Safety Act. Certain non-approved parts or assemblies, installed by the dealer or its agent not authorized by GM, may result in a change to the vehicle's design characteristics and may affect the vehicle's ability to conform to federal law. Dealers must fully understand that non-GM approved parts may not have been validated, tested or certified for use. This puts the dealer at risk for potential liability in the event of a part or vehicle failure. If a GM part failure occurs as the result of the installation or use on a non-GM approved part, the warranty will not be honored.
A good example of non-authorized modification of vehicles is the result of an ever increasing supply of after market devices available to the customer, which claim to increase the horsepower and torque of the Duramax™ Diesel Engines. These include the addition of, but are not limited to one or more of the following modifications:
Propane injection
Nitrous oxide injection
Additional modules (black boxes) that connect to the vehicle wiring systems
Revised engine calibrations downloaded for the engine control module
Calibration modules which connect to the vehicle diagnostic connector
Modification to the engine turbocharger waste gate
Although the installation of these devices, or modification of vehicle components, can increase engine horsepower and torque, they may also negatively affect the engine emissions, reliability and/or durability. In addition, other powertrain components, such as transmissions, universal joints, drive shafts, and front/rear axle components, can be stressed beyond design safety limits by the installation of these devices.
General Motors does not support or endorse the use of devices or modifications that, when installed, increase the engine horsepower and torque.
These same policies apply as they relate to the use of non-GM accessories. Damage or failure from the use or installation of a non-GM accessory will not be covered under warranty. Failure resulting from the alteration or modification of the vehicle, including the cutting, welding or disconnecting of the vehicle's original equipment parts and components will void the warranty.
Additionally, dealers will NOT be reimbursed or compensated by GM in the event of any legal inquiry at either the local, state or federal level that results from the alteration or modification of a vehicle using non-GM approved parts or accessories.
Dealers should be especially cautious of accessory companies that claim the installation of their product will not void the factory warranty. Many times these companies have even given direction on how to quickly disassemble the accessory in an attempt to preclude the manufacturer from finding out that is has been installed.
Any suspect repairs should be reviewed by the Area Service Manager (District Service Manager in Canada) for appropriate repair direction. If it is decided that a goodwill repair is to be made on the vehicle, even with the installation of such non-GM approved components, the customer is to be made aware of General Motors position on this issue and is to sign the appropriate goodwill documentation required by General Motors.
It is imperative for dealers to understand that by installing such devices, they are jeopardizing not only the warranty coverage, but also the performance and reliability of the customer's vehicle.
Old Aug 8, 2004 | 01:24 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
basically unless the mod caused the failure they can't void your warranty...I know that article said any modification to increase HP etc. ....but I doubt seriously they will void your warranty for an air filter
Old Aug 8, 2004 | 01:41 PM
keyscat's Avatar
keyscat
I didn't give the water issue enough thought. I had a Blackwing on my last vette and put the Vortex on the new one. I drive 100 miles a day back and forth to work. Can get caught in some pretty nasty rainstorms. Am I better off getting rid of the Vortex and switching back to the Blackwing? I have noticed in the last few days the car doesn't seem to be accelerating right. (Been driving in rainy weather lately)
Old Aug 8, 2004 | 03:53 PM
-Blue Vette-'s Avatar
-Blue Vette-
Isn't the speed limit in Key West 35 mph?
Old Aug 8, 2004 | 03:56 PM
keyscat's Avatar
keyscat
yep, 35MPH but I work in Marathon , 50 miles up US1
Old Aug 8, 2004 | 09:58 PM
If the aftermarket part causes a failure, then the warranty will be denied. However, for an intake, unless you suck in water, I can't imagine anything serious happening.
Old Aug 8, 2004 | 10:11 PM
SteveL2's Avatar
SteveL2
Sort of funny, but this question has been asked at least since I started reading the forum in 2001, and the good news is at least there's a lot more history now of what has happened with the majority of C5 owners that have done so. The correct answer has already been given, GM can only refuse warranty if the modification causes the damage for which repair is sought. However, the issue of what is the "cause" is a big mystery and very much open to the choice of the dealer.
Bottom lines:
(1) find a good dealer and you won't have to worry about things as minor as an air filter
(2) find a lousy dealer and they'll make your life miserable
(3) open air filters do increase the chance of ingesting water which in turn will destroy your motor, but unless they are located near the ground the risk is not too bad as compared to the stock filter and there's LOTS of folks that have run various aftermarket filters here on the forum (myself included) with very few reported instances of engine lock as a result of water ingestion
(4) Clint Eastwood: "Do you feel lucky punk? Well, do ya?"
To Vortex / Warranty Question
