bill
Old Aug 8, 2004 | 01:38 PM
billhayes's Avatar
billhayes
3rd Gear
Default bill
have a 98 convertible C5, after new top was installed, major leaks and no results from installer. Heard that this was a problem with 98s, anyone got a suggestion on how to fix this one?
Old Aug 8, 2004 | 01:39 PM
billhayes's Avatar
billhayes
3rd Gear
I have a 98 convertible C5, after new top was installed, major leaks and no results from installer. Heard that this was a problem with 98s, anyone got a suggestion on how to fix this one?
Old Aug 8, 2004 | 06:47 PM
Patches's Avatar
Patches
Welcome to the forum.
Never heard of a problem with 98 vert tops leaking.
Anyone else?
Old Aug 8, 2004 | 06:49 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Several of my friends never complained
Old Aug 8, 2004 | 07:25 PM
GrayC5's Avatar
GrayC5
Welcome to the Forum!
Haven't heard of anyone having major problems either. Three things come to mind - condition of weather stripping, top adjustment and window adjustment. I would suggest you look at the weather stripping first then adjust the top and/or windows as necessary. If you're a do-it-yourselfer, I would suggest that you buy a set of the GM Service Manuals (published by Helm) if you don't already have a set. Weather strip replacement and adjustment procedures will be in the Service manual. Otherwise, I would suggest you look around for a competent repair facility to do the work for you.
Good luck with the repairs!
To bill
