Speedy Tips
Old Aug 9, 2004 | 06:55 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Default Speedy Tips
Has anyone drilled a drain hole in their speedway tips? Just installed the B&B PRTs and washed the car...I had a pond inside the exhaust tips when I was done.. Seems a drain hole would work
Old Aug 9, 2004 | 07:00 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Just start the car and it will blow out.
Old Aug 9, 2004 | 07:01 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Magnaflows come with a nice little drain hole in each tip
Old Aug 9, 2004 | 08:21 PM
I have this problem with my B&B Route 66 quad oval tips. I just get the car up to speed and the water disappears.
Old Aug 9, 2004 | 10:53 PM
xilr8n's Avatar
xilr8n
z06 has the holes drilled stock
Old Aug 9, 2004 | 11:59 PM
jrose7004's Avatar
jrose7004
Old Aug 10, 2004 | 12:54 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I agree with all of the above.
Old Aug 10, 2004 | 02:19 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I have Corsa Pro tips, but I always take a wet/dry vac and suck the water out. I use that method for all the little areas like that - side mirrors, side markers, tail lights, etc. Give it a try - works great.
Old Aug 10, 2004 | 05:32 AM
Dustydog's Avatar
Dustydog
Cruise-In VI Veteran
Cruise-In VII Veteran
I have the RT 66 with speedway tips and I just drilled two small holes in each tip last weekend. I made sure they were under the lip and they can not be seen.
Every time I washed the car water would stand in the tips.
To Speedy Tips
