Does anyone know the root cause of the column lock problem? Does the lock motor fail? Does the locking pin bind against the locking plate?
an engineer was rushing out the door on a friday because he was going to get drunk with some friends and while on his way out he found a flaw in the column lock device because he got so trashed monday morning he forgot all about it and the column lock was produced as is
Many theories... few definitive answers.
Theories include:
a) Misalignment and binding, worsening over time, possibly the result of folks using the steering wheel as a brace getting in and out of the car...
b) Column lock motor poorly made and weakening (degrading) over time
c) Longterm effects of summer heat and battery voltage degradation
d) Just a plain old bad design
e) All of the above
Who knows, who cares? My recall notice has arrived and I will be column lock-free by the end of next week!!!
When mine finally went bad I took special interest to find out this answer. I believe it to be an excess current draw from the motor, due either to lack of lubrication or shorting of some of the windings. Though I never pulled the wheel and the motor itself, the evidence was slightly melted wire insulation and (the very first sign) the slightly "relaxing" of the electrical connector pins (in the plug/socket where you plug in the CLBypass). After I "re-bent" the pins, I got another couple weeks out of the system before it failed to un-lock again, and this time it took my big bench power supply to un-lock it (the cigarette lighter cord would NOT supply enough current this time!!).
Dead spot in the actuator 99.9% of the time The fact that I have unlocked at least 100 of them over the past 8 years by simply tapping the actuator with a hammer (lock plate on or off) is proof of that... That is why it is eliminated on the A4 and why there is no guaranteed fix for the M6 short of installing a "fresh" actuator that will fail again in the future or the CLB of course
The latest recall requires a check of the clearance between the lock pin and the lock plate, so it would appear that mechanical binding is at least a contributing factor.
L
The clearance check or "function test" as it is called calls for the tech to simply listen for the possibility of the pin contacting the plate while turning the wheel with the key on.This condition is what potentually can cause locking at speed.Checking the clearance has nothing to do with the failure to unlock issue when turning the key on
