SPONGE...Born Date???
Old Aug 13, 2004 | 06:25 PM
QuikZilver's Avatar
QuikZilver
Thank you very much, Sponge!!!
Old Aug 14, 2004 | 04:05 PM
bartek_72's Avatar
bartek_72
Sponge,
Will be very glad for your help.
VIN: 1G1YY22G825113579
Bartek
Old Aug 14, 2004 | 06:07 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
if possible...
1G1YY22G915110768
id really appreciate it! thanks a lot!
Old Aug 14, 2004 | 06:43 PM
1EvilC5's Avatar
1EvilC5
St. Jude Donor '09
Default Born on Date
Could also help me with a Born on Date.
VIN 1G1YY22G9X5131385
Thanks in Advance...
Phil...
Old Aug 14, 2004 | 08:45 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Originally Posted by bartek_72
Sponge,
Bartek
Open Recall:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004 Open
VIN 1G1YY22G825113579
VEHICLE BUILD
Merchandising Model : 1YY07 -2002 CORVETTE COUPE
Gross Vehicle Weight Rating : 1680 kg (3704 lb) Order Number : N/A
Build Date : 11/12/2001 Build Plant : 125Y
OPTION CODES
AAB - MEMORY CONVENIENCE PKG AG2 - POWER SEAT ADJ - PASSENGER
AK5 - NEXT GENERATION DRIVER & RGHT FRONT PASSENGER AIR BAGS AQ9 - SEAT FRT BKT, PASS/DRIVER RECL
AX4 - EUROPEAN SEAT BELTS BAG - EXPORT PARTS PACKAGING
BGR - PLANT CODE-BOWLING GREEN, KY B4H - EXPORT MOD NOISE CONTROL
B84 - BODY SIDE MOLDINGS CF7 - REMOVABLE SUN ROOF
CJ2 - AUTO TEMP CNTRL SYST. CT1 - COUNTRY - BELGIUM
DD0 - ELEC. MIRROR/DEFOGG. LT. SENS. DD8 - I/S R/V LIGHT SENS. MIRROR
D42 - RR COMPARTMENT SECURITY SHADE EXP - EXPORT PROCESSING OPTION
FE3 - SPORT SUSPENSION SYSTEM G90 - 3.15 AXLE RATIO
G92 - PERFORMANCE AXLE RATIO IL3 - INTERIOR TRIM DESIGN
JL9 - PWR DISC ANTILOCK BRK SYS FR&RR K63 - 110 AMP GENERATOR
LS1 - 5.7L 8 CYL SFI ENGINE MAE - MARKETING AREA EUROPE PROCESSING OPTION
MX0 - AUTO. TRANSMISSION O/D M30 - 4SPD. ELECTRONIC TRANSMISSION
NK4 - LEATHER SPORT STEERING WHEEL NP7 - EEC APPROVED STEERING COLUMN
NT3 - EMISSION SYSTEM EEC QF5 - WHEEL 17 X 8.5 FRT
T2F - EUROPEAN BRAKE PROVISIONS T62 - DELETE DAYTIME RUNNING LAMP
T82 - AUTO ON-OFF CONT HEADLAMPS T84 - RH RULE E MARK HEADLAMPS
T89 - EXPORT TAIL & STOP LAMP T90 - EXPORT SIGNALING & MARKER LAMP
T96 - FOG LAMP UL0 - RADIO: AM/FM STEREO, SEEK/SCAN AUTO REV MUSIC SEARCH CASSETTE AUTO TONE, CLOCK, ETR
UL2 - EUROPEAN RADIO FREQUENCY UV6 - HEAD UP DISPLAY
UV7 - REAR WINDOW ANTENNA UZ6 - 6 SPEAKER SYSTEM
U1S - MULTIPLE COMPACT DISC PLAYER U19 - KILO SPEEDOMETER & ODOMETER
U52 - ELECTRONIC INSTUMENTATION PANEL VC5 - EXPORT SHIPPING LABEL
VD1 - EUROPEAN OPTIONS PROVISION VG1 - UNDERHOOD PROTECTION
VG9 - EXTERIOR BODY WAX PROTECTION VH5 - VEHICLE IDENTIFICATION PLATE
VJ4 - CHILD SEAT WARNING LABEL VL4 - FR LICENSE PLATE MOUNTING EEC
V17 - OCEAN FREIGHT CHARGES V19 - MARINE INSURANCE
V76 - TOW HOOK V78 - DELETE VEHICLE STATEMENT
XGG - P245/45ZR17 BW FRT TIRES YGH - P275/40ZR18 BW RR TIRES
Z51 - PERFORMANCE PACKAGE HANDLING 1SA - PREFERRED EQUIPMENT GROUP 1SA
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER SEATING SURFACE
41U - BLACK
Old Aug 14, 2004 | 08:50 PM
Sponge Vette
Originally Posted by silver6spd C5
if possible...
1G1YY22G915110768
[B]Open Recall:
VIN 1G1YY22G915110768
VEHICLE BUILD
Merchandising Model : 1YY07 -2001 CORVETTE COUPE
Gross Vehicle Weight Rating : 1671 kg (3685 lb) Order Number : CSPT1Z
Build Date : 10/19/2000 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C2L - DUAL REMOVABLE ROOF PANELS DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET FE3 - SPORT SUSPENSION
FE9 - 50-STATE LOW EMISSION VEHICLE GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL4 - ACTIVE HANDLING SYSTEM
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QF5 - POLISHED ALUMINUM WHEEL T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR Z51 - PERFORMANCE HANDLING PACKAGE
1AY - STOCK ORDERS PROC OPTION 1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
11U - LT PEWTER METALLIC 19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING [B]
Old Aug 14, 2004 | 08:53 PM
Sponge Vette
Phil...
VEHICLE BUILD
Gross Vehicle Weight Rating : 1708 kg (3766 lb) Order Number : BNZWW7
Build Date : 06/09/1999 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AAB AG2
AK5 AQ9
BGR B34
CJ2 C2L
DL5 DL8
D42 FE1
FE9 F45
GU2 IL3
JL9 K63
LS1 MX0
M30 NF2
NK4 QD4
T96 UN0
UV6 UV7
UZ6 U1S
U52 VM3
V73 XGG
YGH 1SA
10U 67I
673
For some reason a handful of this, show up has codes only, to see what the codes are go here.Option
Old Aug 16, 2004 | 02:21 AM
Jimdear00Coupe's Avatar
Jimdear00Coupe
If you would could you run my vin
1G1YY22G6Y5107983
Thanks Sponge
Old Aug 16, 2004 | 09:34 AM
C5 KIDD's Avatar
C5 KIDD
hey thanks a lot!! really appreciate it!
Old Aug 16, 2004 | 03:14 PM
Sponge Vette
1G1YY22G6Y5107983
Thanks Sponge
VIN 1G1YY22G6Y5107983
VEHICLE BUILD
Merchandising Model : 1YY07 -2000 CORVETTE COUPE
Gross Vehicle Weight Rating : 1691 kg (3729 lb) Order Number : BWWFX6
Build Date : 10/04/1999 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
C2L - DUAL REMOVABLE ROOF PANELS DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - FEDERAL EMISSIONS
F45 - SELECTIVE REAL TIME DAMPING GU6 - REAR AXLE 3.42 RATIO
LS1 - 5.7L LITER SFI, V8 MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF2 - FEDERAL EMISSION SYSTEM, TIER 1
QD4 - STYLED ALUMINUM WHEEL R9Z - POMS EXPEDITE - SOLD ORDERS
T82 - TWILIGHT SENTINEL T96 - FOG LAMPS
UL0 - AM/FM STEREO CASSETTE RADIO UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - COMPACT 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SA - OPTION PACKAGE - BASE
19I - INT EBONY INTERIOR TRIM 193 - BLACK LEATHER TRIMMED SEATING SURFACE
91U - DARK BOWLING GREEN METALLIC
Open Recall:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004 OpenRC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004 Open
Old Aug 16, 2004 | 03:20 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
If you would be so kind Sir...
1G1YY32G0Y5133162
Thanks!
Old Aug 16, 2004 | 03:22 PM
mopac's Avatar
mopac
Default Sponge Help Build Date
Sponge,
Could you get my build date too. "Vin 1G1YY32G045124584". Thanks
Old Aug 16, 2004 | 03:58 PM
  #33
Sponge Vette
1G1YY32G0Y5133162
Thanks!
VIN 1G1YY32G0Y5133162
VEHICLE BUILD
Merchandising Model : 1YY67 -2000 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1681 kg (3707 lb) Order Number : CMDGTR
Build Date : 06/21/2000 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C05 - CONVERTIBLE FOLDING ROOF
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
FE3 - SPORT SUSPENSION FE9 - FEDERAL EMISSIONS
G90 - REAR AXLE-3.15 RATIO G92 - PERFORMANCE AXLE RATIO
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
UV6 - HEAD UP DISPLAY UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE 1SA - OPTION PACKAGE - BASE
41T - T0P-BLACK 41U - BLACK
Old Aug 16, 2004 | 03:59 PM
  #34
Sponge Vette
Originally Posted by mopac
Sponge,
VIN 1G1YY32G045124584
VEHICLE BUILD
Merchandising Model : 1YY67 -2004 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1673 kg (3689 lb) Order Number : GZWB8H
Build Date : 03/11/2004 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE3 - SPORT SUSPENSION
FE9 - 50-STATE EMISSIONS G90 - REAR AXLE-3.15 RATIO
G92 - AXLE: 3.15 PERFORMANCE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QF5 - HIGH POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL UL0 - AM/FM CASSETTE STEREO
U1S - CD 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER RADIO ANTENNA VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME: FRONT
YGH - REAR TIRE-P275/40ZR18 BW SBR Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS)
1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN 1SZ - PREFERRED EQUIPMENT SAVINGS
67I - LIGHT OAK INTERIOR TRIM 67T - T0P-LIGHT OAK
673 - LT OAK SEATING TRIM 70U - TORCH RED
Old Aug 16, 2004 | 04:54 PM
  #35
dfutrell's Avatar
dfutrell
Sponge,
Can I get you to do mine? Thanks!
1G1YY32G345117998
Old Aug 16, 2004 | 05:42 PM
  #36
jaxgator's Avatar
jaxgator
St. Jude Donor '07
Sponge, thank you very much. I really appreciate you taking the time to do this for me
Old Aug 16, 2004 | 06:34 PM
  #37
G-lock's Avatar
G-lock
SpongeVette- One more. 1G1YY22GXX5101375. Thanx, Jeff
To SPONGE...Born Date???
Old Aug 16, 2004 | 06:48 PM
  #38
YBNORML's Avatar
YBNORML
Can you run vin# 1G1YY22GXY5104293
Old Aug 16, 2004 | 08:33 PM
  #39
Sponge Vette
Originally Posted by dfutrell
Sponge,
1G1YY32G345117998
VIN 1G1YY32G345117998
VEHICLE BUILD
Gross Vehicle Weight Rating : 1673 kg (3689 lb) Order Number : GVMHJ4
Build Date : 12/22/2003 Build Plant : 145Y
OPTION CODES
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS: INSIDE REARVIEW&LEFT OUTSIDE REARVIEW
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3.15 PERFORMANCE RATIO
IL2 - TRIM INTERIOR DESIGN JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL UN0 - AM/FM STEREO W/CD PLAYER
Z15 - COMMEMORATIVE EDITION Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS)
1SC - COMMEMORATIVE EDITION * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN * COMMEMORATIVE EDITION 1SZ - PREFERRED EQUIPMENT SAVINGS
15I - SHALE INTERIOR TRIM 152 - SHALE COMMEMORATIVE
19U - LEMANS BLUE 54T - SHALE
Old Aug 16, 2004 | 08:36 PM
  #40
Sponge Vette
description of Options
VIN 1G1YY22GXX5101375
VEHICLE BUILD
Gross Vehicle Weight Rating : 1677 kg (3698 lb) Order Number : 004F34
Build Date : 08/04/1998 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AG2 AK5
AR9 BGR
B34 CC3
C60 DL5
DL8 D42
FE1 FE9
G90 G92
IP3 JL4
JL9 K63
LS1 MX0
M30 NF2
NK4 QD4
R9U T96
UN0 UV7
UZ6 U52
VM3 V73
XGG YGH
1AY 1SA
19I 193
23U
Description of Options
