When fuel gauge acts up, does the "range" function work?
Old Aug 11, 2004 | 06:39 AM
Patman's Avatar
Patman
Default When fuel gauge acts up, does the "range" function work?
I'm curious, for those of you who have experienced their gas gauge acting erratically, does your range function on the DIC still work? If so, why not just use it to figure out when you need gas?
Old Aug 11, 2004 | 06:48 AM
Killrwheels's Avatar
Killrwheels
NOPE !! Range function changes with gauge. Luckily if I put the car in neutral and rev two times , it moves back to the correct position. I call it the LAZY gas gauge.
Old Aug 11, 2004 | 06:58 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
We've learned to use our trip for our "backup" gas gauge...
Old Aug 11, 2004 | 07:58 AM
jojog's Avatar
jojog
Reset your codes - it will read correctly as will the gauge!
Old Aug 11, 2004 | 08:02 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
No
As others have mentioned, I also use one of the trip odometers as kind of a safety measure when traveling the open wilderness.
Old Aug 11, 2004 | 02:12 PM
When my '99 had this problem, the range readout didn't work either.
To When fuel gauge acts up, does the "range" function work?
