Rear window tint ??
Old Aug 11, 2004 | 08:28 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Default Rear window tint ??
This may sound like a dumb ????
If I tint the back glass will I still be able to use the rear defog without deforming the tint.
Thanks Steve
Old Aug 11, 2004 | 08:41 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Yes, you'll be able to use the rear defogger. I've had all my car windows tinted for years and never have had a problem with the rear defogger.
Jeff
Old Aug 11, 2004 | 08:49 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
that shouldnt be an issue, but be sure you find a good place to do it. The little black dots at the top of the glass can look really bad if they dont do it right. I had both my Camaros done at different shops and I regretted it both times.
Old Aug 11, 2004 | 08:50 AM
BigJoe's Avatar
BigJoe
Only potential problem occurs if and when you want to remove the tint. You have to be really careful not to mess up the defroster. As far as the dots, if you have a good shop do it and then you manually work at pressing the film around the dots for the first week or so, even that shouldn't be a problem.
Old Aug 11, 2004 | 08:51 AM
jrose7004's Avatar
jrose7004
Mine is tinted and I've had no issues!
Old Aug 11, 2004 | 09:33 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Thanks Steve
It is actually good when first tinted to run the defroster to help the tint adhere itself to the window. The defroster will never be an issue with your tint. No need to worry about that.
My problem is I have YET to see in 3 years a C5 coupe rear glass with a tint job that would pass my personal test for quality. No one can seem to tint this window good enough to satisfy me. I am probably just too picky but until I see one that is good enough, I guess I will not have mine tinted.
The dot matrix design at the upper portion of the glass along with the concave design make this window a bitch to do right.
Old Aug 11, 2004 | 09:35 AM
ericdwong's Avatar
ericdwong
Yes If you remove the tint you may damage the defrost. My car was used and since it was a GM cert they stripped the tint and ruined my defrost. I had to do alot of "painting" using conductive paint in order to repair the broken areas. What a pain in the butt and I had to use a razor blade to clean up the patches. Now it doesnt match back there but when I get yet another layer of tint put on it'll hopefully be covered.
Old Aug 11, 2004 | 10:41 AM
sts57c5's Avatar
sts57c5
yes you will be able to use it.
Old Aug 11, 2004 | 11:40 AM
C6 NOIR's Avatar
C6 NOIR
St. Jude Donor '03-'06-'07-'08-'09
both C5's have been tinted without issues...then again, seldom need the defroster in Houston
Old Aug 11, 2004 | 07:06 PM
Gray Weasel's Avatar
Gray Weasel
Thanks Steve
Just be sure that they know what they are doing .....If they are ham handed they can screw up the defrost elements.....
Old Aug 11, 2004 | 09:03 PM
PYRO1's Avatar
PYRO1
Cruise-In VII Veteran
No problems with mine. So far.
Old Aug 11, 2004 | 09:24 PM
Blowtorch's Avatar
Blowtorch
Meet me at Carlisle.....I can show you one that was done correctly!
Old Aug 12, 2004 | 01:44 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
need a dehumidifier
Old Aug 12, 2004 | 02:36 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
FYI TO ALL : Used to be true Joe, but nowadays, if they do it right i.e. Use a steamer when removing, the defroster lines can be saved.
Old Aug 12, 2004 | 07:57 AM
fvaldiv's Avatar
fvaldiv
Blowtorch,
Where did you get your windows done? Can you post pic's?
To Rear window tint ??
