More Air
Old Aug 11, 2004 | 09:36 AM
Steve Zamcheck's Avatar
Steve Zamcheck
Default More Air
What is the least expensive and best way to get more air for my 2004 C5? Should I remove the air filter cover and strap down the air filter or purchase a Z06 cover or a modified air filter cover offered in the mags?Your suggestions will be helpfull.
Steve
Old Aug 11, 2004 | 10:05 AM
jrose7004's Avatar
jrose7004
I would get a Blackwing or a K&N Twin Cone or anything!
Old Aug 11, 2004 | 10:13 AM
1g1yy's Avatar
1g1yy
You could do the zip tie mod, which would be least expensive. Do a search for it.
Old Aug 11, 2004 | 11:30 AM
roscoe118's Avatar
roscoe118
Which is exactly what you described in your post. Don't waste any money on the Z06 box. The "zip tie" mod will work better, and costs basically nothing. Use "large" ties to secure, and seal, the filter.
You'll feel the difference The car may take 50-100 miles to adjust for the increased air flow into the intake.
The Blackwing, or Halltech Stinger, are excellent aftermarket filters that look much better, than the "zip tie" mod, and will get you a tad bit
better performance. But they cost in the $200-$250 range.
Welcome to the addiction
Old Aug 11, 2004 | 11:38 AM
ArmyVette's Avatar
ArmyVette
Originally Posted by roscoe118
:The Blackwing, or Halltech Stinger, are excellent aftermarket filters that look much better, than the "zip tie" mod, and will get you a tad bit better performance. But they cost in the $200-$250 range.
And then there's the Vararam systems which will run you about $350 or so but promise enough additional horsepower to launch you and a passenger into space!
Old Aug 11, 2004 | 12:56 PM
vettenovice's Avatar
vettenovice
IMO, what's the point? Do you really think you'll feel the slight increase in HP? Unless you plan to race it, why spend the money? Use the money to buy gas and enjoy the ride! IMO..
Old Aug 11, 2004 | 01:02 PM
Oliver Sudden's Avatar
Oliver Sudden
If you install the Vararam intake system or any other brand of intake, you will deffinately feel the difference in SOTP performance.
Old Aug 11, 2004 | 02:00 PM
Do the Zip Tie method or get something like the Blackwing or Halltech Stinger. All should deliver better performance.
Old Aug 11, 2004 | 06:08 PM
lt1george's Avatar
lt1george
Default Z06 air box
Want a stock looking set up, buy the factory GM Z06 air box #12567571. GM list price $64.68, another way is to cut a big square
in your stock air box with a dremel. Or buy an aftermaket style, all depends what you what to spend. Save the Wave.>george
Old Aug 11, 2004 | 07:22 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
unless you are going to race it at the track and also do other mods (LT headers, less restrictive exhausts etc. = $3k then you are really not going to get much for your $350 IMHO
Old Aug 11, 2004 | 07:29 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
I've got the BW, install was easy. Step by step is at www.ls1howto.com
Old Aug 11, 2004 | 09:09 PM
xilr8n's Avatar
xilr8n
I vararamed the coupe and zip tied the Z. Ziptie is the best if your not a drag racer, methinks
Noticed on the C6 this past weekend that the new airbox lid is about 1" above the filter and you can see the filter from the sides. They just set it up as a rain shield but left it very open flowing.
Old Aug 11, 2004 | 10:43 PM
Steve Zamcheck
Default More Air
Thank you all for the advise. I will try the tie down 1st and see about making this secure.
Steve Z
Old Aug 11, 2004 | 10:48 PM
Steve Zamcheck
Default 1g1yy----More Air
You said do a search for it. Is there a special way to tie down?
Steve
Old Aug 12, 2004 | 08:55 AM
xilr8n's Avatar
xilr8n
The search will give you the step by step removal instructions (some with picturess).
short version:
unscrew the clamp. pull the crossover off of the grommets. pull the filter housing off the studs (both top and bottom) remove lid. put some zip ties together and wrap the filter on each side. reverse the first 3 steps.
To More Air
