[Z06] Do you shift to neutral at stoplights?
I had my 2002 Z06 w/6K miles in for some warranty work (column lock recall, right door not unlocking, bad washer fluid censor, etc) and complained about how it sometimes will not go into 1st gear when I get the green light at a stop light and I have to start from 2nd.
It is the case where it goes halfway into first but not fully in and will pop back out if you let the clutch out. I got a technician to try it while I was there and he reproduced it a few times, and called GM tech support center (or whatever it is called) about this, but the end result is to drive it some more for now which I am not happy with.
Anyhow, when you come to a stop light that you know will be long as you arrive for example right as it turns red, do you shift to neutral and let the clutch out, or leave it in 1st gear with the clutch pressed to the floor?
I wonder if the user manual says anything about this...
-kg
-kg
Better to leave it in neutral with the clutch engaged.
Holding the clutch pedal down increases the wear on the through-out bearing and the thrust bearing both of which are explensive to replace.
However, in all honesty, I have never worn out a thrust bearing before the clutch.
I usually never downshift unless braking hard at high speed. Downshifting just gives more wear to the clutch. Pads are a lot easier to change
Depending on the light I will wait with car in neutral. Less wear on throwout bearing. Some jurisdictions have laws against coasting up to a light in neutral. They feel if you need to make an evasive manuver you won't be able to. Makes sense.
I let the car slow in gear as I aproach the light and listen to the gurgles and pops from the stingers.. Then out of gear and clutch dis-engaged. No cluthc issues, but mine is a bit noise when out of gear and clutch out when cold.
Dave
Dave
I always shift into neutral and let the clutch out.
I have also found that if mine does not go easily into first gear, if I pull it into 2nd or 4th, then go directly to 1st, it almost always goes into 1st more easily once things are lined up.
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Originally Posted by rbartick
I shift to neutral and release the clutch as I am approaching the light. I have been doing this for 20 years.
, but I may downshift a bit also, depending how fast I'm going & how quickly I need to slow down.
Originally Posted by KGjevre
Anyhow, when you come to a stop light that you know will be long as you arrive for example right as it turns red, do you shift to neutral and let the clutch out, or leave it in 1st gear with the clutch pressed to the floor?kg
It doesn't hurt the clutch to slow the car down in gear and then press the clutch in right before you stop. Maybe if you put the clutch in a half mile from the light, but not right before you stop. I'd rather slow down in gear than just pop it in neutral. Just my preference.
X
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
I go to neutral with the clutch out, then anticipate the light change and shift into first.
If you've got your windows down and the radio off, you might notice that the sound of shifting from N to 1 is audible outside the car - very like racking the slide on a pump shotgun...
Click-ka'chik!
But I've only been driving a stick for a little over a year.
Click-ka'chik!
I go to neutral with the clutch out. As the light changes, I put the clutch in, shift into first, and go.
For casual driving, I use the brakes instead of downshifting. I figure brake parts and labor is cheaper than clutch parts and labor.
dave
dave
