[Z06] Vararam B2 user's
Old Aug 17, 2004 | 12:06 AM
slong's Avatar
slong
All is good. Work is killing me although. I honestly can only say that I won't know about the trip until work decides on when production will halt, and then we will be able to set dates for building shutdowns and re-qualification. They love hanging us by a string.
Originally Posted by stano
Hey Steve not much.
How you been, haven't heard to much from you lately.
Got the car running good and dealing with heating issues otherwise things are good.
You coming up in Oct for my cruise??
Stan
Old Aug 17, 2004 | 06:15 PM
stano's Avatar
stano
Originally Posted by parshooter
Okay, I will reluctantly weigh in; I installed the B2 on my '02 and it has not run right since. The car "stumbles" consistently in third and fourth gear about 2000 rpm and after 400 miles I got a check engine light and severe overheating (240 degrees); took it to the dealer (after I scanned it to find lean right and left banks - 0171 ad 0172); the dealer (real goofballs) said it scanned fine and the reset the computer and could not find anything wrong; after I left the dealer awhile ago it still stumbles in third but not so bad in fourth; the driving around town temperature of coolant is about 210 degrees; before this B2 (for 14,000 miles) my in town and road temp was always 190 derees on the button; this car was a jewel and I fear I screwed it up; I agree with the guy that posted a few back: why mess with an intake that will do 11's; my advice is don't get the B2 and quit messin' with it.
I've been thinking about doing the same thing as you, only I will put the Halltech Trap back on because the car ran fine until the VaraRam went on.
It sounds like you are having the same exact problems as me.
Several people say that that is not the problem but I'm beginning to wonder.
I also agree that it is pretty cheap looking and agree with the fact that there are many places for air to escape.
I'll post my results when I switch them out.
Old Aug 17, 2004 | 07:36 PM
rickvette's Avatar
rickvette
Originally Posted by RoHo
Hey Guy's, I think that I have decided to go with a Vararam B2 induction system, do any of you guy's who have had this unit on your Z06 a while have any negitive things to say about it? After the install will code be cropping up in the DIC and do you think that I will need a tune up? I have seen some post's where some of the guy's were saying that they were running rich after the install. Will the computer adjust to this change after some miles are put on the unit?
Thanks much
RoHo
Here we go- installed a B1 on my 2001 Z06 (replaced Blackwing) and really didn't notice much! I also have headers, carbonfiber airbridge, ported throttlebody and a non worked MAF (screens still in). I had a dyno tune done with the Donaldson Blackwing in. I look at the air filter in this thing and always "admire" the gloobs of glue that hold the pieces together! I really need to dyno with the Donaldson and B1 on the car to see if there is a difference. The one item- driving in the rain is risky with the B1 or B2 compared to the Blackwing.
Old Aug 18, 2004 | 06:15 PM
stano's Avatar
stano
I replaced the VaraRam air box with the stock Z06 air box.
The reason for this is that I noticed when I connected the aftermarket air box to the MAF that it created a small gap on the bottom of the filter box where the K&N filter goes, the lower part that rubs on the cooling fan shroud.
Because you have to slightly lift the MAF to get the connection right, it pulls the bottom of the filter connector slightly apart at that point.
It creates a bend when it is connected.
Also, I was not happy with the way the filter box sealed so I modified the rubber gaskets around the box. I wanted a tighter seal.
For $399.00 you would think that they could have used 4 clips to make a tighter seal. The two rubber connectors that they have now is pretty lame IMHO, especially when your talking about the possibility of dirt or dust being allowed to enter the engine.
With the stock air box everything fits snug now and it looks better.
After a short 40 mile drive I noticed that the car ran alittle smoother and the idle seemed to settle down a tad.
Also, a very slight surge that I had is now gone.
Who knows...time will tell If this works out for the best.
Finally, I can't believe that the after market air box helps enough so as to be concerned about that much of a loss of power or response by using the stock air box.
I'm going to replace the throttle body connector with a smooth connecter for clean air flow to the throttle body.
Old Aug 19, 2004 | 02:01 PM
90 droptop's Avatar
90 droptop
You will not see much difference with the car stationary. The VARARAM comes into it's own while the car is in motion. No "ramair" BUT cold fresh air is what makes the additional power. I picked up 3 mph and 3/10's going from the Blackwing to VARARAM. All the gains were in the 330' to the finish line.
Bottom line, all the serious go fast cars use them, that says it all.
Old Aug 19, 2004 | 02:27 PM
LuS1fer's Avatar
LuS1fer
I don't think it says anything other than you can have a 3/10ths of a second difference in the way you drive your car. Can you comprehend what part of a blink of an eye constitutes 3/10ths. If temperature is the variable then the weather on the day will make as big a difference. I'll say it again, more than one stock Z06 has run 11's. Conclude what you will but I'm prepared to say driver variables are a far more likely explanation. Besides $300 for 3/10ths, hell, I'd give up 3/10ths if someone gave me $300. LOL.
Old Aug 19, 2004 | 03:13 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
In drag racing, 3/10's IS a lot, & usually very expensive once you get into the mid to low 11's or lower!
Old Aug 19, 2004 | 03:56 PM
90 droptop's Avatar
90 droptop
Well, since my car is an A/4 and as consistent as the sunrise, I think it says plenty. Let me put it another way......... 20+ runs without VARARAM vs. 20+ runs with VARARAM. All runs done over a 12 month period, that means diff. temp, weather, track conditions blah blah blah... get the picture!! And the VARARAM runs are quicker.
You conclude whatever YOU want. There is plenty of proof out there to back up my claims..... the difference between you and me is this, I can back it up, what have you done?
As far as you being "prepared" to say driver variables are the explanation, prepared with what......... pure
Wayne FYI Your little tribute to AC/DC Hells Bells. The lyrics are "pouring rain" NOT "fire and rain".
Old Aug 19, 2004 | 04:43 PM
LuS1fer's Avatar
LuS1fer
Whooo...tetchy.
BTW, I know about the lyric but I guess I prefer it my way. I guess modifying something from the original isn't an original idea.
Old Aug 19, 2004 | 05:57 PM
90 droptop's Avatar
90 droptop
Whooo...tetchy.
Whats "tetchy"???
I see reality is something a bit foriegn to you huh.
This board is here to help people, not spew unsubstantiated nonsense.
Old Aug 20, 2004 | 02:07 AM
stano's Avatar
stano
Update on coolant temps...
I think I found the culprit.
I checked my coolant with a coolant tester I bought at Napa and discovered that I had more coolant than water.
The mixture was off.
I drained out about a half gallon of coolant and re-filled it with a half gallon of distilled water.
After a 140 mile round trip that started out in 101-105 temps outside, my coolant didn't go above 201 at 75 mph with the air on and it stayed consisitant at that temp dropping occasionally to 195 to 190 as the temp outside dropped to 100.
On the way home at 88 outside it dropped to 181 at one point and then settled in at 185.
I have a 170 t-stat.
I will check the mixture again in the morning to see if any additional coolant needs to be drained as I'm sure it will take several cycles to mix it completely in the engine.
Just a heads up to those of you experiencing high coolant temps.
This was very encouraging to me
Checked coolant this morning and added about a quart more of distilled water ( 3/4 total ) and after a 120 mile round trip things are back to normal
Heads were off twice and probably an oversight as more coolant was added and the mixture was then heavy on the coolant side and less water.
Just a heads up to those of you doing h/c packages
Old Aug 22, 2004 | 06:39 AM
slong's Avatar
slong
Old Aug 22, 2004 | 10:48 AM
  #33
stano's Avatar
stano
After playing around with different air boxes over the last couple of days, I discovered yesterday that the airbox would not align up straight to the throttle body.
It was off center.
So while connecting the coupler to the throttle body, it would pull the right top of the filter housing up creating a small gap.
I loosened the bottom clamp below the maf sensor that connects to the bottom air shroud and adjusted the filter housing to where it fits snug now.
After R&R-ing the different air boxes I've come to the conclusion that IMHO there is a difference in throttle response and top end between the stock air box and the after market box.
Some say yes, some say no, I wanted to find out for myself.
I'm going to modifiy the Halltech air box to fit and see what results I get from that.
I like the design of his air box the best.
Finally, this was all done in fun and I thought that if something I've discovered could help someone in anyway well, that is why I posted this info.
The more you tinker, the more you learn
I'm not saying all VaraRam's will fit like mine, but if anyone has similar problems they will know how I fixed mine
Old Aug 22, 2004 | 12:30 PM
  #34
'97 C5's Avatar
'97 C5
Al at LAPD did suggest the VaraRam because Tony from AFR was using it and his inlet temps were cooler than mine.
Stan, Tony has a Vortex unit that he has modified for a tighter seal.
After the install the tuner at LAPD did say my temps were down over the Trap by 10-15 degrees.
Stan, on LAPD's dyno your intake temps were lower with the VaraRam, but, that may or may not be attributed to the design…or it might be attributed to the flow of clean, cold air in LAPD’s dyno room design.
Either way, cooler intake air allows me to tune more effectively and the VaraRam delivered just that....at least on that day and in that environment.
I may put the Halltech back on to see if that has anything to do with it..
Stan, that has nothing to do with your temps but if you want to see the difference between the intake systems you have, ask Stan Barber to log the intake air temps and MAF readings. Compare the results.
Take care and see you later...Charlie
Old Aug 22, 2004 | 02:49 PM
  #35
stano's Avatar
stano
Sorry, I thought Tony had the VaraRam.
I got my temps under control by checking my coolant mixture with a tester and discovered that I had much more coolant than water.
When I got the mixtures about 50/50 things got back to normal and the car runs great Charlie
I've deceided to leave the VaraRam on and modifiy the Halltech air bridge to fit just for the heck of it to see what happens if anything.
I'm really happy with the way the car runs and you did an awesome tune for me Charlie I think she has some more left in her
I'm getting excited about the possibilities in Oct. if we're still on
Good to hear from you Charlie
