Born Date
Old Aug 14, 2004 | 07:50 PM
vetpet's Avatar
vetpet
Default Born Date
Hi Sponge Man,
Just purchased a 2001 Millenium Yellow convertible last week and saw that you're the man to go to on the forum for VIN deciphering. Could you do mine when you get a chance? My vin# is 1G1YY32G115122709. Much appreciated.
Old Aug 14, 2004 | 08:43 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Originally Posted by vetpet
Hi Sponge Man,
Glad to be of help. First you have an open recall, make sure you take care of that.
Open recall:
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/27/2004 Open
VIN 1G1YY32G115122709
VEHICLE BUILD
Merchandising Model : 1YY67 -2001 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1667 kg (3676 lb) Order Number : A63005
Build Date : 02/21/2001 Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY DRIVER CONVENIENCE PKG. INCL. SEATS, MIRRORS, RADIO, TEMPERATURE SET AND MODE AG2 - ADJUSTER, 6-WAY POWER SEAT, PASSENGER SIDE
AK5 - RESTRAINT SYSTEM - AIR BAG, DRIVER AND PASSENGER SIDE AQ9 - ARTICULATED SPORT BUCKETS WITH LEATHER SEATING SURFACE
BGR B34 - FRONT CARPETED FLOOR MATS
B84 - BODY SIDE MOULDINGS CJ2 - AIR CONDITIONING - ELECTRONIC CLIMATE CONTROL DUAL ZONE
C05 - FOLDING CONVERTIBLE ROOF DD0 - ELECTRIC REMOTE O/S MIRRORS, DEFOG, LH ELECTROCHROMIC AUTOMATIC DAY/NIGHT
DD8 - ELECTROCHROMIC REAR VIEW MIRROR FE3 - SPORT SUSPENSION
FE9 - FEDERAL CERTIFICATION EMISSION GU6 - 3.42 REAR AXLE RATIO
IL3 JL4 - CONTROL ACTIVE BRAKE
JL9 - BRAKES - ANTI-LOCK K05 - HEATER - ENGINE BLOCK
K63 - GENERATOR 110 AMP LS1 - 5.7L SFI ALUMINUM V8, 350 HP
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NF7 - FEDERAL EMISSION SYSTEM NK4 - STEERING WHEEL - SPORT LEATHER
N37 - TILT/TELESCOPIC STEERING WHEEL QF5 - POLISHED ALUMINUM WHEELS
R7K - MISSING OPTION CREDIT T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - DELCO BOSE AM/FM STEREO, S/S, COMPACT DISC, CLOCK, AUTO TONE,THEFTLOCK,6 SPKR SYSTEM
UV6 - HEAD UP DISPLAY UZ6
U1S - MULTIPLE COMPACT CD CHANGER U19 - KILO SPEEDOMETER
U52 - CLUSTER INST.,ELECTRONIC U75 - AUTOMATIC POWER ANTENNA
V49 - LICENSE PLATE FRAME V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG YGH
Z49 - CANADIAN BASE EQUIPMENT Z51 - PERFORMANCE HANDLING PACKAGE
1SB - PREFERRED EQUIPMENT GROUP - 1SB 19I - GRAY INTERIOR TRIM
193 - BLACK LEATHER 41T - TOP COLOUR - BLACK
79U - MILLENNIUM YELLOW METALLIC
Old Aug 15, 2004 | 01:51 PM
vetpet's Avatar
vetpet
Default Born Date
Thanks Sponge Man, Your info is fantastic. I did have the recall on the column lock looked after a couple of days ago. My car has the magnesium rims on it but according to your data it came with polished rims. This kind of explains why I'm getting a tire pressure monitor message in the information center. Turns out all of the tire sensors are damaged and as well, the right front rim is slightly bent. Bringing the car back tomorrow where I purchased it and they're going to send it to the GM dealer near them to have the rim and sensors replaced as well as have an alignment done (steering wheel slightly off center). I may look at putting the polished rims back on since they were part of the original equipment package just to keep everything to factory spec. I'm a little curious as my car does have a black leather interior but your spec sheet also shows code 19I - gray interior trim? There is no gray trim anywhere in the car except for the corvette lettering in the seats. Is this what the code means?
Thanks Again
PetVet
Old Aug 16, 2004 | 03:21 PM
Sponge Vette
Here is a complete List of Options and there codes.
Options List
To Born Date
