[Z06] Shifter Rattle..aarrgghh!
Old Aug 15, 2004 | 11:40 PM
Matt69-ZO6's Avatar
Matt69-ZO6
Default Shifter Rattle..aarrgghh!
The shifter in the Z started rattling and driving my crazy. Thought maybe the **** was just loose. Nope.
It will stop with a bit of downward pressure on the ****.
Any ideas before I tear into it?
I've been thinking about changing the shifter (hate 2nd to 3rd), but do not want something so stiff my wife can't shift it.
Old Aug 16, 2004 | 12:00 AM
KMeloney's Avatar
KMeloney
If you want a better shifter without added shift effort, buck-up for the Mallett. In my opinion, it's the best (and I've tried a lot of shifters).
-Kirk
Old Aug 16, 2004 | 10:54 PM
Shylor's Avatar
Shylor
Matt,
You didn't say if it was the stock shifter or an aftermarket shifter. Either way try a new **** like MGW's Pistol Grip. It got rid of my Hurst rattle.
Old Aug 16, 2004 | 11:06 PM
Matt69-ZO6's Avatar
Matt69-ZO6
The shifter is stock. The rattle SEEMS like it is coming from the bottom of the shaft and not the ****....
I like the Mallet Shifter, but $$$$$!!!!!! Is it really that much better the a $155 Hurst? I having trouble justifying the $155 for the Hurst!
Maybe at FunFest, someone will let me take a turn at their car's shifter.....
Old Aug 16, 2004 | 11:42 PM
Shylor's Avatar
Shylor
With any aftermarket shifter you are going to get more noise than the stock shifter. But you will definately get shorter throws and a more precise shift.
Old Aug 17, 2004 | 12:00 AM
xsiveone's Avatar
xsiveone
If you're getting rattles or vibration through the stock shifter there is not one aftermarket shifter on the market that will be any quieter for you. Even the Mallett.
X
Old Aug 17, 2004 | 12:14 AM
Matt69-ZO6's Avatar
Matt69-ZO6
Hey, I didn't put the Stingers on to quiet the car down!
If I put an aftermarket shifter in, drivetrain noise transfer through the shifter is not an issue...I was just wondering if someone had ran into a stock shifter rattle, like I have.
Something has come loose or is rubbing up against something. The noise was not there until just over 12k miles. It is a very noticeable rattle under acceleration and just plain annoying at a constant speed, plus your arm gets tired pushing down on the d--n thing!
Thanks for the input! Somebody got a used Mallet shifter for sale or trade for a slightly used stocker?!
Old Aug 17, 2004 | 12:51 AM
Shylor's Avatar
Shylor
Is the key that holds the **** in place secure? Check it under the shift pattern emblem on the ****. Otherwise I don't know what else could be loose. The C5 shifter is a simple design so not much else could go wrong.
To Shifter Rattle..aarrgghh!
