St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
car pictures
Ok guys people on the forum and friends have told me how to post pictures of my car so i am going to give it a shot it if it does not work it is back to the drawing board.Let me know.........charlene
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
You'll need to enclose the image in IMG tags. You'll also need to use a valid URL. http:lling.photobucket.com is not valid because it is missing the // after the colon ( : ). I would assume that the photobucket.com site allows you to upload images to your directory. And after that you would also need to put the image name at the end of the URL. For example, let's say I had just registered under the name of jaxgator at photobucket.com. I have uploaded an image called myc5.jpg. The way to get the image to show is as follows [img] http://www.photobucket.com/jaxgator/myc5.jpg [/img] w/o the spaces after and before the IMG tags. I had to use the spaces to get the entire URL to show for you.
After you have uploaded your pics to photobucket, click on one of the pictures to open it. The right-click the picture and choose properties. Copy the location of the picture. It will start with http://.....
Then paste the location into your post. Hope this helps.
St. Jude Donor '07
Actually, I just signed up to photobucket and see that after you've uploaded an image it gives you the URL or IMG verbiage down at the bottom of the page. Just highlight it, copy it, and then paste it in here.
If you use the URL verbiage you get the following...
If you can see your picture at Photobucket here's what to do.
1) Right click your mouse while anywhere over your picture.
2) A drop down style menu will open up, slide over in that menu and left click the bottom choice "Properties"
3) That will open up the Properties window.
4) In the center of that window is the "Address: URL line.
5) Copy that entire address line: Starts with http:// and will end with .jpg
Then here at the forum, paste that entire line into your post inbetween the 2 IMG markers. It should look like this:
[img]the address you copied from the properties box[/img]
IF you do all that, your picture will show up here.
Thanks to all who gave instructions for PHOTOBUCKET.. I'm not the original poster, but am new to forum and wanted to know how to post pictures - but was too afraid to ask ..
Maybe now, I can post pictures of my new MSG'04 vert...
JCR_Indy
There is a help section here. Click "Forums" in the top left of your screen...scroll down to "Help/Feedback".
