Hi All,
First I would like to thank the guys who posted answers to my questions last week about the CLB Device.
I just received my Kit from Corvettes Of Houston. The instruction sheet that came with the device has slightly different info than the instructions from LS1 How To .com.
The Insruction Sheet from Corvettes Of Houston States:
"if a "service column lock" or pull key and wait 10 sec. error is displayed, remove the ignition key and fuses No. 25 and No. 29 from the fuse panel. Wait 1 minute and replace."
The instructions from LS1 How To. com does not say anything about removing fuses.
My question is: Is the fuse box they are talking about the one that is inside the car under the glove compartment??
After you install the column lock, IF when you insert your key you get this error, then you pull those 2 fuses. Mine went in without a hitch, put the key in and was all good. As for the fuse box, I believe it is the one at the passenger foot well.
Neil
From: When I say who is the masta you gotsta say Shonuff
Neil
