Problem with AM radio reception
Old Aug 17, 2004 | 05:45 AM
Patman's Avatar
Patman
Default Problem with AM radio reception
Has anyone else had this happen with their BOSE system? Most of the time now when I switch to AM radio, there is no signal. There is an AM news radio channel up here which gives out awesome traffic reports every ten minutes, but for the last 4 or 5 days I haven't been able to listen, except once or twice when reception kicked in for a few minutes.
How do I fix this?
Old Aug 17, 2004 | 03:08 PM
JC in XTC5's Avatar
JC in XTC5
Check your antenna connectors at the front windshield (should be somewhere above mirror mount) and rear window (in the middle of the hatch at the top). I would guess that the rear one is for AM more than the front, since the front is just a dipole pattern (common for FM) and the rear is more intricate. I would guess maybe the connector to the etching is loose or came off.
Has anyone done any work on the car lately, either in those areas or in the dash?
Old Aug 17, 2004 | 05:29 PM
NYN8IVE's Avatar
NYN8IVE
How do I fix this?
No AM signal is usually indicative of a bad or unplugged Antenna. Your FM will still work marginally even though antenna may be defective or unplugged. If it's intermittent you will have to plug in a new antenna when it is not getting a signal to determine if that's the cause.
Good Luck
Old Aug 17, 2004 | 06:01 PM
BBQ's Avatar
BBQ
How do I fix this?
Stock Bose units are notorious for this. I have the same problem. There are plenty of former posts on it.
Old Aug 17, 2004 | 06:17 PM
Matt69-ZO6's Avatar
Matt69-ZO6
AM? Dude?!
Old Aug 17, 2004 | 08:29 PM
Patman's Avatar
Patman
Originally Posted by Matt69-ZO6
AM? Dude?!
Like I mentioned, it's only to quickly listen to the traffic and weather forecast, then I turn on the CD player anyhow. It was working this afternoon for me though, strange.
I just got the car on Aug 7th and nobody has touched anything that would cause this. The problem just showed up a couple of days ago for the first time. I'll check the connection at the top of the windshield first.
To Problem with AM radio reception
