Thanks to the Forum
Thanks to the Forum
Thanks to all you guys that have offered your expertise on 'vette issues. With your help I finally found all of the A/C drain hoses. I pull the battery and found evidence of acid leak. Replaced it with a Optima Red Top. I can display and reset fault codes. I was able to determine that the column lock issue was repaired. Much other info as well. Could'nt have done it without you.
Received 19,397 Likes
'20-'21-'22-'23-'24
The forum is a wealth of information. Just about any problem or question you may have, it can be answered here.
Received 1,680 Likes
This is a cool place!
