No bass after using Soundgate interface. Help!
Old Aug 18, 2004 | 10:21 PM
JTS97Z28's Avatar
JTS97Z28
Default No bass after using Soundgate interface. Help!
I just got done installing my Pioneer Avic-N1 in my 99 hardtop vette. I purchased the Soundgate GMCRV1 interface adapter..Sound quality is very good however it doesnt seem that my door subs are working. I have messed with all settings on the headunit, and used the turn **** that came with the interface adapter. That does nothing. Only my 3.5" and 5.25" speakers are working. Any ideas?
Old Aug 19, 2004 | 01:21 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
ok i can shed some light on this you need to hook the speakers up to low and high side of radio the subs turn on with a sound signal.i used a metra harness and it even says it in the instructions. Also their is a amp turn on wire you need to hook up on the stock harness to the amp on switch on radio harness.
Old Aug 19, 2004 | 01:55 AM
JTS97Z28's Avatar
JTS97Z28
Yeah I figured it out I forgot to attach the blue Bose amp turn on wire. Thanks for the help.
Old Aug 19, 2004 | 09:54 AM
noran01's Avatar
noran01
Also if there is no bass from the doors look at the instructions and follow the procedure for moving the ground wire from pin 9 to pin 3(i think). Thats what i had to do in my '04 coupe.
To No bass after using Soundgate interface. Help!
