Problem with Door Lights.
Old Aug 19, 2004 | 01:01 PM
ebodiford's Avatar
ebodiford
8th Gear
Default Problem with Door Lights.
I recently purchased a 2000 vert. The lights in both doors do not burn when the doors are open. Also, the light under the hood does not burn when the hood is up. Could it be a fuse?
Old Aug 19, 2004 | 01:06 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Prbably a fuse, however I took the bulb out of my hood so it's not on all the time at a carshow if it's windy.
Old Aug 20, 2004 | 12:09 AM
SilverBullit02's Avatar
SilverBullit02
Door lights???? C5's don't have door lights. Those red thingys are only reflectors. I wish they were really lights though. Also, the hood light... A lot of dealers disconnect the hood light so it won't stay on while the hood is up for display. However, the light has a timer/switch. It will shut itself off after 15 minutes if the hood is left open. The switch could also be faulty.
Old Aug 20, 2004 | 12:31 AM
lt1george's Avatar
lt1george
Default hood light
I unplugged my underhood light.Follow the wire down and make sure it's plugged together.Good Luck.Save the Wave.>George
To Problem with Door Lights.
