heads only performance?
Old Aug 20, 2004 | 07:28 AM
98vert6spd's Avatar
98vert6spd
Default heads only performance?
I want to put some heads on my 98 mn6 im not afraid to do the heads but i am terrified of messing with the cam. I dont think ill ever be able to get hte thing back in sync as far as the timing goes. Its probably because im cross eyed who knows. Is there any performanc gains to be had just but changing the heads? which would you go with? Am i crazy about the cam thing?
Old Aug 20, 2004 | 10:41 AM
98vert6spd's Avatar
98vert6spd
NOONE ever responds to my threads
ill get mor views....watch this
Old Aug 20, 2004 | 12:20 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I would try posting this in the C5 Tech section..you'll get more replies there I am sure.
Heads and Cam are a very good way to get some good HP gains. If you are terrified of messing with the Cam/engine I would find a good shop in OH that will do that for you. Also, do a search here on the forum there is a lot of great tech info and people that will help out.
Good luck
To heads only performance?
