[Z06] CF hood?
Old Aug 20, 2004 | 09:48 AM
Z06Fix's Avatar
Z06Fix
Default CF hood?
Is it just the Z16 that comes with this or is it all 04 Z's Also is it that much lighter? is it worth buying? I think I heard it was like 12lbs lighter. I don't see that big of a deal with it but I guess every pound helps at the track.
Old Aug 20, 2004 | 09:58 AM
QuikZilver's Avatar
QuikZilver
The CF hood is only available on the Z16. I looked at it on GM's parts site and to place an order for the hood, you need to have a VIN of a Z16. If you don't, they won't sell it to you. Good thing with the forum is you might find a Z16 owner that can help you out.
Old Aug 20, 2004 | 11:43 AM
Andy64's Avatar
Andy64
As far as the weight issue goes, it is 10lbs lighter than the standard Z06 hood. Does that really matter ... thats based on what you want out of your car. If you are just crusin with it, then I would save the money. If you are watching and wanting to reduce your cars weight, then it's something to consider. Weight is really the only benefit it provides and might not look quite as good painted as standard hood outside of the factory process. Although supposedly very strong (CF is supposedly 10x stronger than equivalent weight in steel), the hood feels quite flimsy to the touch when attempting to close, etc. depending on what other mods you plan, saving 10lbs on the hood could offset other gains you may be adding, however, you want the weight distribution maintained, so I would not recommend adding 10lbs in the rear and removing the 10lbs up front, etc.
Good luck with your mods !
Old Aug 20, 2004 | 02:37 PM
RyanZ06's Avatar
RyanZ06
Actually the Z06 is weight biased towards the front. Adding weight to the rear, and removing weight from the front could potentially make the car handle better. This obviously should only be measured on a set of corner weight scales.
Old Aug 20, 2004 | 02:46 PM
DirtyRed's Avatar
DirtyRed
I've been considering a CF hood. VISRacing.com has an OEM style hood that is very high quality about $550. They also have a raised cowl induction hood and one with vents all over.
Old Aug 20, 2004 | 03:13 PM
ZFORME's Avatar
ZFORME
It is not any better or worse than a regular glass hood, somewhat lighter.
Old Aug 20, 2004 | 04:46 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Aug 20, 2004 | 04:48 PM
xsiveone's Avatar
xsiveone
Same goes with the wheels. I heard that GM even started wanting to see a copy of the registration because too many people were using other people's VIN's to buy the polished wheels.
X
Old Aug 20, 2004 | 07:50 PM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
I went with an aftermarket CF hood, primarily because I wanted the CF to show through on the outside as well as when I lift the hood
Old Aug 21, 2004 | 01:03 PM
Greg H's Avatar
Greg H
I saw a ricer at a car show with a CF hood with the CF showing thru. It was an awesome look. Too bad it was on a ricer.
Levettegrl, do you have any pics online to show your hood paint? Sounds cool.
Old Aug 21, 2004 | 04:08 PM
levettegrl's Avatar
levettegrl
yes-here's my vette on the Vette Essentials web site (Leslie-WV)
http://vetteessentials.com/customer_...stomers01.html
Old Aug 21, 2004 | 08:26 PM
StanChampion's Avatar
StanChampion
My Zpreg CF hood weighs 13 lbs
Old Aug 21, 2004 | 08:49 PM
User 81424's Avatar
User 81424
It also removes 10lbs that are high up and up front, that has more of an advantage than removing 10lbs that might be low and centered.
Many of us suspect that the real reason behind this hood is so GM could get experience with CF for the C6 Z06.
Old Aug 21, 2004 | 08:56 PM
dragon84's Avatar
dragon84
hey Stan where can I get a hood like that and how much.. thanks
Old Aug 21, 2004 | 10:39 PM
Yano's Avatar
Yano
That is the Halltech Stinger hood.
I am not sure if they still sell the hood or not.
Old Aug 22, 2004 | 02:02 AM
StanChampion
Nope they do not sell it anymore. Good and bad I guess.
Awesome hood though.
Yano did you ever get yours?????????????
intel
To CF hood?
