Starting Problems
Old Aug 20, 2004 | 04:08 PM
Sprags2004's Avatar
Sprags2004
Default Starting Problems
If I use the Keyless Remote to unlock my '02 MN6 Coupe and then get in and put the key in the ignition the memory settings move my seat and steering wheel and mirrors to my settings and the car starts. If I leave the car unlocked and get in and then put the key in the ignition the memory settings for the seat and steering wheel and mirrors do not function and the the car will not start. Any idea what the problem could be?
Thanks in advance,
Blake
Old Aug 20, 2004 | 04:39 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
This is how the memory operates (see below), not sure why it won't start, it could be the alarm system.
When first entering your vehicle, after pressing the
unlock button on your remote keyless entry transmitter
or a MEMORY button, a recall of your settings will
occur when the door is closed and the ignition key is
in the ignition switch. As the memory settings are
recalled, the light above the button will flash until the
correct settings are achieved, then glow for five seconds
when complete.
Memory recall will not work if the vehicle is moving.
Memory recall will be temporarily interrupted during
engine crank.
If easy entry is on, you must press the MEMORY button
to reset the seat.
