98 Column Lock
Old Aug 20, 2004 | 10:15 PM
acecpa's Avatar
acecpa
Default 98 Column Lock
My 98 now sits in a parking garage since the steering column locked this afternoon. I can drive front and back but cannot turn the wheels.
A typical tow truck cannot fit in the garage and I can't turn the car left or right to drive it out of the garage.
Any ideas on how I can get out of there? Is there a way to disable the column lock?
Old Aug 20, 2004 | 10:26 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Often several firm tugs of the steering wheel to the left and right will dislodge the pin. Try this then see if the column unlocks after you turn the key to the right to the point before starting. This usually works and then you can install a CLB yourself or start the car and drive it to a dealer and have them service it under the recall. Hope this helps.
Old Aug 20, 2004 | 10:36 PM
GrayC5's Avatar
GrayC5
From C5 Tech Tips: How to Overcome a Column Lock Failure. Good luck!
Old Aug 21, 2004 | 10:02 AM
Cajun99's Avatar
Cajun99
Old Aug 21, 2004 | 10:05 AM
jrose7004's Avatar
jrose7004
Good luck!!
Old Aug 21, 2004 | 10:21 AM
RCK1999's Avatar
RCK1999
Hopefully you can get the wheel to unlock. If not, ask the towing companies if they are equiped with dollies. These dollies go under the wheels, so the tires are off the ground. You can even get your own dollies from PepBoys, Sears and the like and move the car around yourself.
To 98 Column Lock
