Shifting Problems???
Old Aug 21, 2004 | 06:49 PM
CO YGOSLOW's Avatar
CO YGOSLOW
Default Shifting Problems???
Have an 04 vert 6speed, bought it with 12 miles. Been having problems slipping into 5th gear. Normally will slip it into 3rd by mistake. Motion to 5th has to be exagerated. Today made that exagerated motion and got a quick grind to warn me I was about to slip into reverse (first time this happened). Have I caused any damage (no noises after the fact)? Is this common? Any tricks to overcome this problem? Any mods to fix it?
Thx in advance
Old Aug 21, 2004 | 06:55 PM
Patches's Avatar
Patches
If you were moving and you were trying to shift to fifth and you were able to reach reverse then you do have a problem because there is a reverse gear lockout solenoid that prevents you from shifting into reverse gear while in foward motion. It probably wasn't reverse you hit but your synchros could need adjustment.
