Vararam installed, now she smokes...LITERALLY!!!
Old Aug 22, 2004 | 09:59 PM
GRAYT VERT's Avatar
GRAYT VERT
From: Not QUITE the armpit of Southern Maryland, but scary close...
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'06
Default Vararam installed, now she smokes...LITERALLY!!!
Got my Vararam installed today with the K&N filter. Started it afterward and just let it run for a bit. After a bit, I noticed smoke coming from the exhaust like on a cold day, but it was 75 outside. This is definitely NOT normal, at least to me. Checked the gauges, everything looked good, nothing on the DIC. All I can figure is maybe the smoke is from a little of the oil on the filter maybe being sucked in and burned. Anybody else have or heard of this happen? Any other ideas?
Thanks,
Dave
Old Aug 22, 2004 | 10:25 PM
Old Timer's Avatar
Old Timer
David,
If indeed it is from your K&N filter and it is substantial enough to be seen out the exhaust, I would suspect that you have probably oiled your Mass airflow sensor which will affect your tuning. If your maf is oiled it will need to be cleaned.
Old Aug 22, 2004 | 10:28 PM
Tino's Avatar
Tino
Default Vararam
Did you get to test it out? Let us know what your seat of the pants impression is at low and wot. I would also say it is the oil.
Thanks Tino
Old Aug 22, 2004 | 10:36 PM
You may have way too much oil on the K&N. Must be sucking it in the engine and burning it off.
Old Aug 22, 2004 | 10:41 PM
GRAYT VERT's Avatar
GRAYT VERT
David,
I just put the filter in straight out of the box. Thought there was a good bit of oil on it, but not really all that familiar with it, thought it might be normal. So, how should I go about cleaning the sensor?
THanks again,
DAve
Old Aug 23, 2004 | 12:08 AM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
I would removed and inspect the MAF and airbridge thoroughly.
I have never experienced this issue but it stands to reason there would
be residue or evidence of the oil being pulled through these components.
Good luck getting this resolved!
Old Aug 23, 2004 | 12:27 AM
Slash's Avatar
Slash
Install some oil nozzles in the rear and machine guns in the front and you can be Bond, James Bond.
Old Aug 23, 2004 | 08:20 AM
GRAYT VERT's Avatar
GRAYT VERT
ttt
To Vararam installed, now she smokes...LITERALLY!!!
