What is "hubcentric"?
Old Aug 24, 2004 | 09:51 PM
Railfan's Avatar
Railfan
Default What is "hubcentric"?
I was told by a tire man to make sure any new rims I purchase are "hubcentric". What is hubcentric? And which chrome replacement rims are hubcentric?
Thanks,
Mike
Old Aug 24, 2004 | 09:58 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
From Discount Tires' web site....(http://www.discounttiredirect.com/di...foWheelFAQ.jsp)
"Most aftermarket wheels are manufactured with a center hole that will fit a wide range of vehicles. The hub-centric ring is used to fill any gap that may exist between this hole and the vehicle's hub, thus centering the wheel on the axle. If you have vibrations after installing new wheels, chances are hub-centric rings were not used."
Hope this helps.
Ducman69's Avatar
Ducman69
Don't worry about it... I think almost any wheel available now is going to be hubcentric.
Hubcentric means the center hub keeps the wheel centered and holds the weight. The lugs just make sure it doesn't fall off.
Lugcentric allows tapered lugs to support all the weight and center the wheel. Doesn't center well this way and is just an inferior design from what I've heard.
Old Aug 24, 2004 | 10:00 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Hubcentric means the hub (center hole) of the wheel is machined (or uses adapter rings) to fit the exact diameter of the the hub/spindle of the car. This is the primary means to perfectly center the wheel and insure it spins true.
The other varient is lugcentric, which means the lugnuts take on the duty of perfectly centering the wheel, and the hub bore of the wheel is unimportant.
I would think you'd have a tough time to find a c5 wheel that isn't hubcentric, so I wouldn't worry too much about that.
Old Aug 24, 2004 | 10:29 PM
Railfan's Avatar
Railfan
Thanks for the info. Hopefully, the Z05 chrome rims I am planning on getting from one of the forum vendors are hubcentric.
Thanks again.
Mike
To What is "hubcentric"?
