Build Date Help Sponge!
Old Aug 25, 2004 | 01:28 PM
Grady54's Avatar
Grady54
Default Build Date Help Sponge!
Need build date for 1G1YY22G045103793 Thanks
Old Aug 25, 2004 | 01:31 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
VIN 1G1YY22G045103793
VEHICLE BUILD
Merchandising Model : 1YY07 -2004 CORVETTE COUPE
Gross Vehicle Weight Rating : 1682 kg (3709 lb) Order Number : GKFNMS
Build Date : 08/12/2003 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C2L - ROOF PACKAGE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE EMISSIONS
GU2 - REAR AXLE 2.73 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QF5 - HIGH POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS
T82 - TWILIGHT SENTINEL UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - CD 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME: FRONT
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS 88U - MEDIUM SPIRAL GRAY METALLIC
92I - LT GRAY INTERIOR TRIM 923 - LT GRAY SEATING TRIM
Old Aug 25, 2004 | 01:40 PM
Grady54's Avatar
Grady54
Default Build Date
Thanks again for the info
To Build Date Help Sponge!
