[Z06] Halltech Stinger Questions
Old Aug 25, 2004 | 07:16 PM
RoHo's Avatar
RoHo
Default Halltech Stinger Questions
Hey Guy's- For the last six or so weeks I have been reading all of the opinons regarding all of the most popular air intake system, I was going to go with a Vararam B2 but didn't know if it would be compatible with my new ACI front spoiler and when I saw that Halltech was having a Stinger sale this week for only $199.00 I thought-What the Hell and I ordered one for my 04 Z06 from Nate at Corvette Garage. Question is, some of the threads are stating you will have to get a tune after the installation because it will throwing codes and running lean. Is this a given for all 04's or just some, and when they say " tune " are we talking a dyno tune or one of the hand held type units. Just trying to get a handle on it before my Halltech arrives.
Thanks ! RoHo
Old Aug 25, 2004 | 10:23 PM
ryanc440's Avatar
ryanc440
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I have the Halltech TRAP on my Z and it did need some computer tuning. I got the LS1 edit and after a few runs on the dyno with the car hooked up to the laptop we were able to get a few more ponies and get the air-fuel ratio set properly. The car's computer will "learn" some upgrades, but I think Halltech's and Vararams cause such an increase in airflow that the computer can't keep up without some help; IMO of course.
Old Aug 25, 2004 | 10:45 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
The "increase in airflow" is not causing the tuning problem. The problem is inaccurate sensor readings and inaccurate initial fuel delivery from the PCM which results in a large amount of fuel trim correction.
Old Aug 26, 2004 | 01:44 AM
Subw00er's Avatar
Subw00er
Ack! I just ordered one from Corvette Garage too. Am I going to get check engine lights now?! I dont think there are any places near me to get tune-ups, unless the dealer can do it.
Old Aug 26, 2004 | 08:03 AM
Evolution's Avatar
Evolution
Yeah, unfortunately my understanding is that the codes were mostly throwing in 04 Z's. I might be wrong, but that is what I'm reading on the different boards. And they are having to get a tune done. There have only been a couple I have seen that say they have not recieved a SES light yet.
There was someone that posted that said a screened maf would stop the code. He said he put a screen around the maf (homemade) and that the SES light went away. Don't know if any validity to it, but hey, figure I'd tell ya.
Will
Old Aug 26, 2004 | 08:22 AM
hogpowr's Avatar
hogpowr
I've got an 04 Z06 with a halltech on order. I will let everyone know if it throws codes.
Old Aug 26, 2004 | 09:30 AM
QuikZilver's Avatar
QuikZilver
From posts I read last month about the Stinger is that the 04 Z's and a couple 03 Z's throw a lean code with the Stinger. Some people let the codes come up and kept clearing them and once the PCM learned about the extra air, they stopped coming up. Others had the PCM reprogrammed by a tuner to do away with the codes as well. 01's, 02's and most 03's do not have this problem as they run richer. Good luck to all of you. Hope it doesn't throw any codes for you!!
Old Aug 26, 2004 | 11:32 AM
Weedo's Avatar
Weedo
I have an '03 with Halltech TRAP. No codes or lights. I have put about 600 or so miles on it with the TRAP and have been down the 1/4 mile about 7 passes.
Old Aug 26, 2004 | 01:11 PM
RussBt's Avatar
RussBt
As I said above (and in many other threads) an "increase in airflow" is not causing the tuning problem. The problem is inaccurate sensor readings and inaccurate initial fuel delivery from the PCM which results in a large amount of fuel trim correction. PCM learning will not solve this problem. PCM learning is what is actually throwing the code.
Old Aug 26, 2004 | 02:04 PM
hogpowr's Avatar
hogpowr
I know the car will run leaner with the halltech. My question is, will the code really do anything to the car. Does the pcm adjust at all, is there a chance of it learning or do I have to absolutely get a tune if it throws a code.? Can I drive it with the code showing?
Old Aug 26, 2004 | 03:33 PM
RussBt's Avatar
RussBt
Lean codes are not "learned out". Learning is causing them. See my posts in this thread from yesterday.
http://forums.corvetteforum.com/showthread.php?t=891484
Driving with the code popping is kind of silly. Your car will run better with the stock box.
Old Aug 27, 2004 | 01:02 AM
IGO200's Avatar
IGO200
I'm confused. Is the HAlltech TRAP the same deal except longer and further from the airbridge? Is there a $200 advantage?
Old Sep 9, 2004 | 12:32 AM
Evolution's Avatar
Evolution
The Halltech Trap has piping to run the intake into the front bumper assembly. Hench, producing more HP. The Halltech Stinger replaces the factory airbox with a Filter element at half the price.
You shouldn't just drive around with codes thrown.
Old Sep 9, 2004 | 12:44 AM
Subw00er's Avatar
Subw00er
If I throw codes, what are my options if I dont know anyone within 4hrs drive that has a ls1 edit? Are there other ways to relearn? Something I can buy? Dealer assistance? Thanks.
Old Sep 9, 2004 | 01:58 PM
Jim M's Avatar
Jim M
St. Jude Donor '08
Jim Hall stated that the screenless MAF in 04 Zs is causing the problem. I guess the 04s are tuned different from the factory, because with the exception of a few 03s, it's the year most affected. The MAF sensor is giving inaccurate readings of air flow at low throttle openings, due to turbulence, as compared to what the oxygen sensors are reading in the exhaust. This apparently causes the PCM to over adjust the fuel trims, eventually triggering the check engine light and codes 0171 and 0174 (lean banks 1 and 2). The cure is a screened MAF from a 2001 Z06. The screen smooths the airflow, enabling more accurate readings. I think the 2001 MAFs are available from GM Parts Direct for about a $100. I'm only repeating what I've read in other threads. Of course, you can have the car tuned for the Halltech, which should result in more horsepower and eliminate the check engine light and codes, or run the stock air box with a K&N filter.
Old Sep 9, 2004 | 06:41 PM
mmorse's Avatar
mmorse
This is correct. I have an '04 that threw codes with the Stinger. The trick is to smooth out the airflow that passes over the MAF wires. I tried the ziptie mod with stock box and K&N filter. IMO, the Stinger is much better. I devised my own mod that has been code free for over 1000 miles now. Getting that great Stinger induced throttle response and no codes. It only cost me about $6 and an hour or so of time to install it.
Basically I bought a small plastic clothes dryer vent, used only the piece that sits outside the house and mounted it upside down through the shroud directly in the center of where the filter sits. Now my Stinger gets additional cold air from the underside of the filter smoothing the flow over the MAF wires. It does the same thing the screen does on screened MAFs. at least that is the theory and so far so good. Going to an '01 MAF or devising a screen should also work.
Don't let the slight chance your car may throw codes stop you from the benefits of a Stinger. IMO, too much upside to be had.
mark
Old Sep 10, 2004 | 12:28 AM
Subw00er's Avatar
Subw00er
Is it possible to add a screen somehow? How close does the screen need to be to the sensors (less than 1 inch?)? How tight is the screen mesh on an '01 c5?
I could see bracing a screen mesh material in front of the maf by pinning it in between metal rods that extend outside of the walls of the intake tube. It would look something like this:
I'd have to secure the rods with good locking collars on the outside of the tube and make sure that the rods were a tight fit to the tube and sealed properly. Just a quick idea, I'm sure there are others. It seems a shame to spend $100 on a maf that is the same except for the addition of a wire mesh.
I could do the air hole idea too I suppose. Mark, do you think the same effect positive effect could be realized if the filter itself was lifted higher to allow more air underneath the filter element, or do you think you have some sort of a ram air effect where air is forced to that area of the filter?
To Halltech Stinger Questions
Old Sep 10, 2004 | 12:17 PM
mmorse's Avatar
mmorse
I don't know. I suspect not. The trick is to force a laminar flow. The air coming from under the filter doesn't have any right angles to traverse like the air coming in throught the side of the filter. My guess is the wires are getting enough smooth air from under the filter to overcome the turbulence. And I stress, it's a guess.
mark
Old Sep 11, 2004 | 10:42 PM
ghostRder's Avatar
ghostRder
Hmm O2 sensor prehaps? Got headers on this vette?
Old Sep 12, 2004 | 08:20 PM
Subw00er's Avatar
Subw00er
no headers, its a stock 04 z06.
