Easy entry stopped working?
Old Aug 26, 2004 | 01:43 PM
Mike04Z06's Avatar
Mike04Z06
Default Easy entry stopped working?
Ok I have easy entry set to on so that the seat moves back when I get out of the car and then moves forward when I put the key in. It stopped working today. I was driving home and didn't like the position the seat was in so I moved it up and forward a tiny bit and then saved it to memory 1 as always, and when I got out of the car, the easy entry didn't move the seat back.
I went into options and set easy entry back to off, then back to on, then when I got back in the car and got out later, it still didn't work.
Anyone know what might be causing it to stop working?
Old Aug 26, 2004 | 01:51 PM
JCR_Indy's Avatar
JCR_Indy
Sure you have the right key? I picked up my #2 key the other day (by mistake) and it took me awhile to figure out why my seats wouldn't work like they were suppose to.. Just a thought...
JCR_Indy
Old Aug 26, 2004 | 01:53 PM
Mike04Z06's Avatar
Mike04Z06
JCR_Indy
I thought of that but I watch the yellow light on memory 1 light up when my unlock button is pressed, plus my fiance has the other key and i haven't seen it since i bought the car, and my keyless entry has a big 1 on the back of it
Also, it was working when I left home this morning but stopped working at lunch
Old Aug 26, 2004 | 01:56 PM
JCR_Indy's Avatar
JCR_Indy
Could it be a fuse? Seats work, manually - correct? If so, probably not a fuse... Others with more technical abilities will step-up - hopefilly.
good luck..
JCR_Indy
Old Aug 26, 2004 | 01:58 PM
Mike04Z06's Avatar
Mike04Z06
Yep the seats work manually just fine and the memory button still works. It's really weird.
Old Aug 26, 2004 | 06:25 PM
Try doing it with the car running with the key just in the on postion. Sometimes I have to do this with mine to get it to work right.
Old Aug 26, 2004 | 11:39 PM
Mike04Z06's Avatar
Mike04Z06
I'll give it a try and report my findings tomorrow
To Easy entry stopped working?
