keyless remote issue
Old Aug 26, 2004 | 02:23 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default keyless remote issue
my remote was working fine... then it stopped, I figured the battery died.
So I went and replace the battery, then re-synced it.
now it only works from about 3 feet away from the vette. I even when in and "re-trained" it, still the same thing.
when I shake the FOB, I hear a rattle, it sounds like it's coming from the silver cylinder inside (ocsillator, maybe) anyone else have the same problem?
Old Aug 26, 2004 | 03:58 PM
geerp12's Avatar
geerp12
sounds like you need a new remote!!
Old Aug 26, 2004 | 04:51 PM
ic98's Avatar
ic98
My remote has the same rattle and short range. I was going to replace the battery but haven't yet
Old Aug 26, 2004 | 05:14 PM
klp's Avatar
klp
I replace the battery in both of my Key FOBs and I have the same experience. After re-training them, they work great as long as you're sitting in the car. Once you get out and move away, they quit working. I'm really interested in the response to this issue.
Old Aug 26, 2004 | 06:08 PM
Have you tried your other Fob? If it does the same thing, then it could be the receiver in the car.
Old Aug 27, 2004 | 08:52 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
I didn't get a seconf FOB.
Old Aug 27, 2004 | 11:22 AM
jrose7004's Avatar
jrose7004
Old Aug 27, 2004 | 11:36 AM
BlackMagicC5's Avatar
BlackMagicC5
I got the rattle after replacing my battery, but now it does the passive thing all the time. It has a mind of its own now.
Old Aug 27, 2004 | 01:10 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
what's the price on a new FOB?
will a remote from a 01 corvette work? I don't use the passive anyway.
Old Aug 27, 2004 | 01:44 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You see them on Ebay all of the time. 97's, 98's and I think 99's all use the same remote. The key to it is to make sure that the GM part number on the back matches. It should say 10253839.
This little device, meant to be a convenience has proven to be one of the biggest P.I.T.A.'s for me anyway - and it sounds like for a lot of other folks, too.
Of course you can buy them new - I'd check Fred Beans or Fichtner, but I think they retail for about $99. Good luck!
Old Aug 27, 2004 | 03:31 PM
bluevert99's Avatar
bluevert99
Try moving the passive switch back and forth so that it ends up in active mode. This worked for me.
To keyless remote issue
