OEM C5 wheel specs
Old Aug 27, 2004 | 09:22 AM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Default OEM C5 wheel specs
In my search, I've found different numbers for both offset and backspace for the rear 18x9.5 wheel. Can anyone provide all of the info, total width, offset and back space?
FS & BS should equal 9.5" and overall width from outside of lip to outside of lip is ~10.1".
I posted this in C5 Tech and in the wheels forum, no help yet. Anyone?
Thanks!
Old Aug 27, 2004 | 01:02 PM
74-Roadster
St. Jude Donor '06
Default Come on now . . .
ttt
Old Aug 27, 2004 | 10:00 PM
74-Roadster
St. Jude Donor '06
ttt
Old Aug 27, 2004 | 10:11 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I don't know the exact offsets of the "standard" C5 wheels, only the specs of the wider Z06 wheels. I suppose I could go out an measure my stock wheels sitting in the garage.
I can maybe answer your real underlying question if you are considering an alternate wheel and need to know if they will fit, or are wondering what to order.
Old Aug 27, 2004 | 10:16 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Also, total width is almost always 1" wider than the (stated) width. A 9.5" wheel will typically measure 10.5" wide overall. The nominal wheel width is measured to the inside of the lips where the tire bead seats.
Backspacing, however, is a measure to the outside of the rear lip, so no, FS + BS will not be 9.5"...it will be 10.5".
Old Aug 28, 2004 | 05:46 AM
74-Roadster
St. Jude Donor '06
Okay. I agree (double checked what I thought and realized my error). I have seen 63 or 65 mm offset stated along with 7.5" backspace and that doesn't add up. With a 10.5" overall width, 7.5" backspace equates to ~57mm offset.
If you have wheels sitting in the garage, please measure overall width and the backspace. I'd love to know the real numbers. Since my wheels are mounted, meauring the overall width is very difficult and I'm too lazy to spend an hour or two just measuring a wheel to get info I won't need for quite a while. :o
Old Aug 31, 2004 | 06:57 AM
C5 Frederik's Avatar
C5 Frederik
Here are the data for OEM Mag-wheels. Maybe they are same as the aluminum ones:
front 17 x 8.5 offset 60mm
rear 18 x 9.5 offset 65mm
Frederik
To OEM C5 wheel specs
