Tire sensor
Old Aug 27, 2004 | 01:40 PM
moorevett's Avatar
moorevett
Cruising
Default Tire sensor
I'm in need of some advice on Tire Sensors. I have a 97 and my right rear sensor is reading Rxxx. I take it that means it's bad. Can I fix this myself or do I need to take it into the dealer?
Old Aug 27, 2004 | 01:52 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
You can do it yourself, no need to take it to the dealer.
It probably just needs to be reprogrammed.
Click on this link for the procedure:
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Aug 27, 2004 | 05:15 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
I've tried this procedure a few times on my 98 for the FL sensor not reading any pressure. I'm guessing the battery in the sensor is probably dead ( although the relearning procedure DOES recognize all 4 of the sensors). I just check the tire weekly with a digital gauge to make sure pressure is ok, and oh yeah, I have to reset the DIC every time I start the car to clear the error message.
Old Aug 27, 2004 | 05:43 PM
Try to do a relearn on the sensors. All four will have to be done, but all you need is a strong magnet. The procedure is accessed through the DIC. Good luck. Hope this is all it is.
Old Aug 27, 2004 | 09:22 PM
XCESIVE's Avatar
XCESIVE
I'll be changing my wheels next week but using my existing tires...i'll be changing my sensors over also...will i need to reprogram them as well?..plus..where do i get a battery for the sensors at?..thanks
To Tire sensor
