[Z06] clock running fast
Old Aug 28, 2004 | 09:14 AM
Steve Zaino's Avatar
Steve Zaino
Default clock running fast
My clock runs fast. I keep resetting it, and before you know it it is 5, 10 now 20 minutes fast. Haven't seen any other post regarding this issue.
Anyone know what is going on here?
Old Aug 28, 2004 | 10:12 AM
Andy64's Avatar
Andy64
If I had to take a guess, I suspect the clock is just an internal circuit within the radio unit and I suspect the only way to fix that is to have the radio serviced or replaced ... but I could be wrong. Good luck, hope you get to the bottom of it quickly and painlessly.
BTW - I assume you are referring only to the clock on the radio. Have you checked the Trip elapsed time function within the DIC ? I suggest resetting both at the same time and then compare together to see if perhaps they are in sync. If so, then there could be a bigger problem more integral to the cars computer itself.
