K.p.h. Default
Old Aug 28, 2004 | 07:31 PM
ronjon's Avatar
ronjon
Default K.p.h. Default
K.P.H. DEFAULT Does any one know how to Default the speedometer to read K.P.H. not M.P.H. for instance if you dis-connect the battery then re- connect it it will always default to M.P.H. on a US spec carI and on a export spec car will default to KPH I want the US spec car to default to KPH . I believe it is a programming issue through the B.C.M. with the use of TECH 2. How to go about it is what I am trying to achieve.
RON.
Old Aug 28, 2004 | 07:40 PM
LoneStarFRC's Avatar
LoneStarFRC
I'm not positive but that may be something that a TECH 2 scan tool can do. I would think all the export vehicles would be set-up this way but I'm not sure if this is programmable at the dealer level. You might check with your dealer and see if it is. HTH
Robert
Old Aug 28, 2004 | 08:29 PM
Patman's Avatar
Patman
Even though I live in Canada, I wish my car would default to mph on startup, since I always switch it there anyhow, as I prefer all of the temperature readings to be in Farenheit. I forgot to ask if the tuner could change this for me last week when I got my car dyno tuned.
Old Aug 28, 2004 | 08:37 PM
eel's Avatar
eel
Read your Owners manual, you can default it to KPH with the DIC
EEL
Old Aug 28, 2004 | 08:44 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
I live in Canada and have 2001 vette and spend a lot of time in the US working so I drive in MPH. Whenever I start the car it always set to the last one I selected.
Old Aug 28, 2004 | 10:22 PM
ronjon's Avatar
ronjon
Default kmh default
I understand all this but you disconnect the battery,re connect it again and it will always default to mph on a US spec car I want it to default to kmh after you re connect the battery.
RON.
Old Aug 28, 2004 | 10:53 PM
Try reprogramming the computer - this may work. Your dealership or a good shop with a Tech II could give you a better idea if this is possible.
Old Aug 29, 2004 | 05:07 AM
Patman's Avatar
Patman
EEL
Can this be done on 98s too? I read my owner's manual just a few days ago and I don't recall seeing this in there. What does it say to do in order to get it to default where you want it to?
To K.p.h. Default
