Window problems
Old Aug 31, 2004 | 06:57 PM
gbm's Avatar
gbm
Default Window problems
passenger side window won't roll down; driver's side is ok. Checked all fuses, didn't see anything. Anyone have a similar problem or have any suggestions??
Thanks!
GM
Old Aug 31, 2004 | 07:00 PM
LiquidDI's Avatar
LiquidDI
problably a dead window motor.
Old Aug 31, 2004 | 07:33 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Seems to be a common problem. Mine went out too. Actuator died. Not cheap, either.
Good luck.
Old Aug 31, 2004 | 07:42 PM
LiquidDI's Avatar
LiquidDI
It's cheap if you go to auto zone and get a new motor there and replace it yourself
Old Aug 31, 2004 | 08:13 PM
Patches's Avatar
Patches
Email me at edbon@adelphia.net and I'll email you the info to diy.
Old Aug 31, 2004 | 08:20 PM
RPHCRMZ51's Avatar
RPHCRMZ51
I have had the same problem. If you will hold down the "down" button and close the door a little harder than normal this will uually get it to work. I think the trick is to use the window often as it tends to get stuck.
Old Aug 31, 2004 | 08:53 PM
'99 Feather's Avatar
'99 Feather
I've had this happen several times. The first time I had the thing replaced/repaired under warranty. Since then I started using the trick stated above. It usually to "fixes" the problem. Now I try to remember to lower the passenger window every time I start the car.
Old Aug 31, 2004 | 10:31 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
had the same problem here turned out it was just an actuator that they replaced
Old Aug 31, 2004 | 11:43 PM
GrayC5's Avatar
GrayC5
There is a C5 Tech Tip that basically says the same thing. Once they have all the Forum problems corrected, you should be able to view the C5 Tech Tips then.
Old Sep 1, 2004 | 12:35 AM
Zonify's Avatar
Zonify
Mine was same thing dead motor.
Old Sep 1, 2004 | 09:01 AM
gbm's Avatar
gbm
Default Stuck Window
That did it! Slammed the door about 5-6 times and it finally broke loose.
Thanks for the help and comments everyone!!
Old Sep 1, 2004 | 09:47 AM
vettexan's Avatar
vettexan
Active Streak: 90 Days
Might be a dumb question but...why is it only the passenger side? Lack of use?
Old Sep 1, 2004 | 12:30 PM
FlyNLow's Avatar
FlyNLow
My problem was a disconnected cable inside the door - it had popped apart - I removed the door panel, reconnected the cable, and it worked fine. Took about 10 minutes at most. You may want to check this, if nothing else resolves the issue.
To Window problems
