Ambient Temperature Sensor Follow-Up
Old Sep 1, 2004 | 02:31 PM
klp's Avatar
klp
Default Ambient Temperature Sensor Follow-Up
I requested and got excellent feedback on replacing my ambient temperature sensor about a week ago. When I removed the old sensor, the pins and connector were so corroded that the pins actually broke off of the sensor and remained inside the connector. I attempted to salvage the connector because the parts shop at my local dealer told me they didn't sell the connectors. He indicated I would have to buy the whole wire harness. The sensor was only $14 so I couldn't see spending hundreds on a wire harness. After doing my best with the connector, I hooked it all back up and it still didn't work. I've been looking in ernest for a connector. I finally called another Chev dealer on a whim and he told me they do sell the pigtails with the connector.... I picked it up, removed the old connector, soldered the new one in place and my problems are solved. The pigtail cost about $24 bucks. It appears that this is a common problem, so I hope this helps.
Old Sep 1, 2004 | 02:40 PM
Yoggi's Avatar
Yoggi
Glad you got it fixed. Mine did the same thing , but, the shop got the pigtail and spliced it on. No harness needed!!
Old Sep 1, 2004 | 02:47 PM
JOE1998's Avatar
JOE1998
KLP-
Could you tell me where the sensor is and the easiest way to get at it?
My car's sensor is not working either, but I can't find it
Old Sep 1, 2004 | 03:07 PM
klp's Avatar
klp
The sensor is located on the passenger side. If you jack your car up, look inside the radiator cavity and you'll see it protruding. It's about the diameter of a pencil and protrudes about 1 to 1 1/2 inches into the cavity. To get to it, you have to remove a couple of the plastic pieces like you would if you were replacing a fog lamp or turn signal lamp. Make sure you tell the parts shop that you need the ambient temperature sensor and not the block temperature sensor.
Old Sep 1, 2004 | 11:45 PM
Congrats on getting it fixed. Sure beats spending big dollars.
Old Sep 2, 2004 | 01:14 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
man ive had this exact issue this week also.
coroded and broke pin off had to but the 23 dollar pig tail.
Weird seems a lot of people are have the same problem right now
2000 vette here
Old Sep 2, 2004 | 08:02 AM
Fastbasser's Avatar
Fastbasser
Default Hmmmmmmm
My outside temp is reading about 20 degrees cooler.. Mines a 2000 also.. AC works fine though.. HMMMMMMMMMMMMMMMMMMMMMMMM
Old Sep 2, 2004 | 09:55 AM
klp's Avatar
klp
There's a threshold at which your A/C will stop coming on. I think it's around 37 degrees.
Old Sep 2, 2004 | 04:29 PM
Wolfmanjohn's Avatar
Wolfmanjohn
That is correct!! Below that, if you press the A/C button, the LED will flash at you about 5 times, then go out, indicating no compressor engagement.
To Ambient Temperature Sensor Follow-Up
