Help! Battery runs down over night.
Old Sep 1, 2004 | 06:53 PM
jwhitene's Avatar
jwhitene
1st Gear
Default Help! Battery runs down over night.
This is my first posting, so please bare with me on this. I have a problem with my 86 vette that has boggled the minds of the true novice vette guys. One day I walk out to my garage and I hear this noise coming from my vette. It was the blower motor, it was turning very slowly and making a tipical low battery electric motor noise.
I tried to start the car and the battery was almost dead and wouldn't even crank it over once. I charged the battery and when I reinstalled the negitive battery cable the blower motor started turning again. Now this was a first. I started the engine and drove the car for the first time in a month. I drove about thirty miles and returned home. All the while I was driving the blower motor was turning without the switch being moved. I came home and parked the car and shut the engine off. The blower stop turning and I thought that was the end of it.
This same scenario has happened at least four consecutive times. Finally the battery gave up and I installed a brand new OPTIMA 900. The same thing the next day! I have had alot of vette people tell me things, of which I have tried. I have disconnected things like the under the hood lights and still the same thing. Disconnected the blower motor and the battery stays up fine for as long as I want it to.
It seems to me that there should be a blower relay that might be failing, allowing the motor to come on and then run the battery down. The problem is I can't find a blower relay or anthing remotely close to what looks like a blower motor relay. I bought a Chilton book for this corvette and after I purchased it, I find this disclamier that they don't have anything in the book about A/C due to libilities.
Old Sep 1, 2004 | 06:56 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Your best bet would be to post this in the C4 section where other forum members may have experience the same or similar problem. Mnay C5 had a problem like this but it was due to the battery from GM
Old Sep 1, 2004 | 11:35 PM
Don't know if this is it, but I'd say you have a short somewhere that is allowing the blower motor to complete a circuit without going through the switch. Probably the C4 section is best for answers to this question. Good luck finding out what it the cause.
To Help! Battery runs down over night.
