Any Suggestions?
Old Sep 3, 2004 | 10:47 AM
JL99C5's Avatar
JL99C5
Default Any Suggestions?
I'm new to the forum and this my 1st C5. I have owned the car for about a month now, and I must say... wished I would bought a C5 much earlier. I love this car! but, I have noticed a hard time shifting into 1st gear when I come to complete stop at lights. it doesn't happen every time. reverse is a little tuff too. I have a 99 coupe w/ 43k on it. is it my syncros? any advice would be appreciated. thanks
Old Sep 3, 2004 | 11:01 AM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Have you tried letting the clutch out, then back in on those occasions?
You may need to do this a couple times on occassion. If that doesn't help
then it might be the syncros.
You may want to do a flush and fill on the tranny. If that doesn't help, it could be the syncros. Have a good mechanic look it over for you. Hopefully it will not be something major.
Old Sep 3, 2004 | 11:23 AM
JL99C5's Avatar
JL99C5
if i drop it into 2nd then back up 1st, no problem goes right into gear.
Old Sep 3, 2004 | 11:38 AM
C6~Missle's Avatar
C6~Missle
Agreed... works for me and seems normal.. also going to 2nd then 1st works too.. the splines sometimes dont line up and need to be re-aligned.
Old Sep 3, 2004 | 11:40 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
My MN6 used to be a little hard to shift sometimes. I have a B&M Ripper shifter and I thought that was it. I had the tranny flushed and refilled with Red-Line and I noticed an improvement and the shifting was easier.
I still can't get reverse if the engine isn't running, but with it running - no problems.
You didn't say if you have an aftermarket shifter - but the Hurst and the B&M make a huge difference in the throws and make for a very "positive" action.
Old Sep 3, 2004 | 11:58 AM
Slash's Avatar
Slash
My suggestion is to post your threads with a more specific subject.
Old Sep 3, 2004 | 12:59 PM
ACELR8N's Avatar
ACELR8N
Mine occassionally won't go into either reverse or first also. Always seems to happen on a hill too, so I look like a jerk rolling in the wrong direction. Just go through the H pattern, back through neutral and reselect your gear.
Old Sep 3, 2004 | 01:07 PM
mforman42's Avatar
mforman42
When each of my C5s was new, I sometimes had the same problem. However, after they got broken in, it stopped. Usually about 2-3000 miles. Because yours is well past the break-in period, I'd suspect either worn syncros or a mis-adjusted shift mechanism. Because the transmission is in the rear, the action will never be as direct as with earlier 'Vettes.
Old Sep 3, 2004 | 03:13 PM
JL99C5's Avatar
JL99C5
thanks for all the insight guys. just fyi my car is mostly stock. k&n intake and corsa cat-back exhaust are the only mods... so far.
To Any Suggestions?
