Sound deadening material ???
Old Sep 3, 2004 | 07:04 PM
aficionado's Avatar
aficionado
Default Sound deadening material ???
If I search the internet I find a lot of products.
Does anybody have experience with this?
I would be looking for putting stuff in the rear coupe area, probably under the carpet, maybe around the wheel well area (inside).
I figure I'd take it step by step, if under the carpet works, then I'll stop at that.
Any suggestions would be appreciated.
Old Sep 3, 2004 | 07:29 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Don't have any personal experience, but I've heard this is good stuff.
http://www.hometheaterhifi.com/volum...ng-6-2003.html
Old Sep 3, 2004 | 07:42 PM
Last C5's Avatar
Last C5
On the TECH forum they determined that the best noise reduction material they had found was divorce papers. I don't recommend that but I have used Dynamat, available through Crutchfield & other stereo dealers, with good success. It's a little spendy though.
Old Sep 3, 2004 | 08:47 PM
Dark-Knight's Avatar
Dark-Knight
I've used Dynamats in the past (C4). Funny you posted, bought some at lunch today with a buddy who has a reasonace problem in his C5. Just doing the back deck on C4 cut noise by 1/4, would have been better had I done wheel well covers
Sheets are 4' X 24", $35 each, pricey but easy to install. Back deck area should take 2 to 3 hours.
Old Sep 3, 2004 | 10:23 PM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
ear plugs are cheaper and easily removed and quickly if you need to go back to stock
Old Sep 3, 2004 | 11:05 PM
Mike Mercury's Avatar
Mike Mercury
http://forums.corvetteforum.com/showthread.php?t=897041
Old Sep 3, 2004 | 11:09 PM
yellow01's Avatar
yellow01
I used dynamat in my jeep wrangler (about as sound-proof-less as you can get) and it worked well - but it is expensive. The plus is it is very easy to use (sheets that are adhesive) and easy to trim etc.
Old Sep 4, 2004 | 12:01 AM
1FunZ06's Avatar
1FunZ06
After installing Borla Quad tips, I loved the sound but started getting some headaches. Someone suggested a $99 3 inch foam partition from Ecklers. It has a C5 and Z06 logo too! Works great! No headaches, great Borla sound!
Old Sep 4, 2004 | 01:23 AM
OOBlackconvert's Avatar
OOBlackconvert
I have used a material called Acumat in a Mustang and it works awesome. The before and after difference was amazing. I have also used Dynamat before, but it requires a lot of heating and dosen't stick very well. Acumat is peal and stick and they also offer three differen't types.
http://www.scosche.com/accumat.aspx
To Sound deadening material ???
