Major Panic This Morning.................
Now I'm in the PANIC MODE, but I try to start car, motor fires and immediately dies, try this about half a dozen times, same thing, even tryed pumping the gas pedal. By now I have that sick feeling in my stomach, so I get out of the car and take a walk, thinking what to do.
I decided to disconnect the battery and see if that would clear the system, but while looking at how many things I would need to remove to disconnect the battery without scratching my painted covers, I remembered the Window Valet I had installed, my aching brain said give that a try, since it was easy to do.
Well I reached under the dash and unplugged the Window Valet and figured that nothing would change, but I inserted the key and turned till the DIC was displaying, WOW........... everything was normal, so I cranked the motor and it fired immediately. Now my stomach is doing flops and my blood pressure is starting to ease a bit.
I leave the car running a few minutes and figured I would try the Window Valet to comfirm what appeared to be a failure. I plugged in the Valet and inserted the key and turned till the DIC displayed, again everything was Normal.
I guess I will monitor for awhile and see if it happens again. If anyone has some weirds things happen to there car and have a Window Valet, it maybe you problem.
It is now time for a stogie and a drink, blood pressure has receded from about 300 to normal, head still aches, but aleast I won't have to schedule a dealer visit.
and i hit unlock to turn it off but nothing happened. I assume by hitting unlock it wourld turn off the alarm, but it didn't. I also have the WV module. I havent' tried it withit out yet just cause its not a HUGE deal.
Scott
I have a WV and have never experienced that (and hope never to).
