Battery Tender Wires?
Old Sep 6, 2004 | 08:51 PM
caffeine's Avatar
caffeine
Default Battery Tender Wires?
Buying a battery tender for the winter to store my baby. I don't have it yet but hope that the hood does not have to be open.Any suggestions from experts on where to place the wires?
Old Sep 6, 2004 | 09:03 PM
caffeine's Avatar
caffeine
Sorry. Second part of the question. What is the best or what is everyone using as far as battery tendors?
Old Sep 6, 2004 | 09:13 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
The battery tender will fit beside the battery. You can run an extension cord from under the car to the inside.
Old Sep 6, 2004 | 09:16 PM
caffeine's Avatar
caffeine
lager99, Red Deer gets dam cold, as it does here? Who's tender to you use.
Old Sep 6, 2004 | 09:24 PM
DRILL629's Avatar
DRILL629
I purchased mine from Ecklers. It run about $50. Works fine during the cold months when you can't put it on the road because of the weather.
jerrymcb's Avatar
jerrymcb
Get a VDC Electronics Battery Minder or a Deltran Battery
Tender Plus. You can leave either of these on indefinately
with no fear of battery damage.
Old Sep 7, 2004 | 07:51 AM
C5 Frederik's Avatar
C5 Frederik
I always use the cigar lighter plug. Works fine, no problems during 3 winters.
Frederik
Old Sep 7, 2004 | 08:12 AM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
I place the tender unit on a rubber mat besides the car and then feed the wires with the clip through the engin compartment. That way I can keep the hood closed. I do this on both vettes all winter and it works good.
To Battery Tender Wires?
