Corsa X Pipe installation question????
Old Sep 7, 2004 | 10:41 PM
LiquidDI's Avatar
LiquidDI
Default Corsa X Pipe installation question????
Can you cut the stock pipe with a reciprocating saw?? I don't have a pipe cutter but was wondering if the saw will do the same job? thanks!
Old Sep 7, 2004 | 10:49 PM
Rickk's Avatar
Rickk
I helped a friend install an x-pipe 2 years ago. We used a hack saw to take out the stock system. There wasn't a lot of room under there. If you do use a power saw, be very careful.
Old Sep 7, 2004 | 10:52 PM
LiquidDI's Avatar
LiquidDI
Thanks! That's what I was thinking. I'll just go slow and be very careful. It is possible to get the reciprocating saw in there though right?
Old Sep 7, 2004 | 10:55 PM
Rickk's Avatar
Rickk
Yep, its possible.
Old Sep 7, 2004 | 11:10 PM
streetstrip's Avatar
streetstrip
I just did a similar installation, It is pretty easy to just drop the whole center sectioin out. Measure three times, cut once. Just my opinion.
good luck
Old Sep 8, 2004 | 01:28 AM
Deb's 2004's Avatar
Deb's 2004
I had mine done at a local muffler shop and they used a reciprocating saw. it was very efficient and quite easy.
just make sure you measure properly to determine the cut location.
Regards
Deborah
To Corsa X Pipe installation question????
