Problem message in DIC????? Help!!!
Old Sep 8, 2004 | 09:29 AM
bradleyls103's Avatar
bradleyls103
Default Problem message in DIC????? Help!!!
This morning I got into my 2003 Corvette. when I started the car the DIC said "Charge System Fault" for a few seconds and then went away. My volt gauge was reading around 14 like normal, and as I drove to work it stayed between 13.6 to 14.1 Like Normal????? The car seems to be fine. What does that mean???
Old Sep 8, 2004 | 10:12 AM
INTRUBL's Avatar
INTRUBL
It usually happens to me when I let it sit for a while, I would not worry.
Old Sep 8, 2004 | 11:41 AM
Landru's Avatar
Landru
HA!
Believe it or not you're being warned the Delco battery is about to fail, possibly leaving you stranded, certainly causing you embarrassment and/or inconvenience.
Was getting the same error code on my '03.
Made a decision after it happened 2-3 times that instead of having Chevrolet replace the battery with the same defective garbage?
I'd just bite the bullet & replace the thing now before a failure, and do so with a battery of my own choosing.
That meant just one thing, Optima Red Top.
Shockingly I haven't thrown that code again, since.
Old Sep 8, 2004 | 11:43 AM
vettexan's Avatar
vettexan
Active Streak: 90 Days
I had the same problem with my 2003. Does it seem like it is not starting right up? Almost like a hesitation when you turn the key? The dealer put in a new alternator under warranty - still showed same message for about a week even though it was starting better. I took it back and they said that it was showing false readings and should go away. They said that nothing was showing on the computer. It did go away and I have not seen the message since.
BTW - A new battery was installed about 6 months ago. Original died with no warning.
Old Sep 8, 2004 | 12:18 PM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Mine does this often. Even after a new Battery!
To Problem message in DIC????? Help!!!
