Kumho ECSTA MX Installed
Old Sep 9, 2004 | 05:42 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Default Kumho ECSTA MX Installed
Just got home from having a set of Kumho ECSTA MX's installed as replacements for GY EMTs and to go with my Hotchkis/Bilstein mods.
What a difference!!! Right off the bat the road noise and ride improvements are incredible. (My exhaust even sounds better now). I haven't been able to check for traction improvement on any significant turns, but having more rubber on the road should improve that, too.
After just a very short test ride home I'd have to say the difference is very satisfying and worth the change!
Old Sep 9, 2004 | 06:34 PM
c5hobo's Avatar
c5hobo
Cruise-In V Veteran
St. Jude Contributor '04
I felt the same way when I got mine on. What a difference!
Old Sep 9, 2004 | 07:35 PM
Richin Chicago's Avatar
Richin Chicago
Love those tires! If you have the chance to get on a roadcourse I have found 36 pounds for all but the driver side rear (which is 34) works best.
Old Sep 9, 2004 | 07:44 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
How will I be able to hear you as you disappear in my rearview mirror ??
...kinda makes you giddy doesnt it...
I remember how it felt to go from Goodyear EMT's to even Michelin's ...sticky and quiet... what a combo!
I was just looking up my info on the Nittos Im installing...when I saw your thread...
...so for now you may have the edge especially on the windier roads...
Old Sep 9, 2004 | 07:48 PM
StuzVette's Avatar
StuzVette
...now looking to Kumho as alternative...
Old Sep 9, 2004 | 07:50 PM
VetteSiNz's Avatar
VetteSiNz
Good for you, at least your hearing the true tune of your exhaust. I know for sure my EMTs are much louder than my Stingers.
Old Sep 9, 2004 | 08:19 PM
mountainbiker2's Avatar
mountainbiker2
Is that hot or cold?
Thanks. Steve
Old Sep 9, 2004 | 08:24 PM
vette99coupe's Avatar
vette99coupe
I just bought a 99 coupe that has almost new Goodyear runflats but I'm sure I will be in the market for new tires sooner or later (probably sooner, lol). I've heard that Kuhmo makes runflats but can't seem to find them anywhere. I would go with regular tires if it weren't for the "no spare" problem. Just don't know if I can drive around like that. Any opinions?
Old Sep 9, 2004 | 08:54 PM
Richin Chicago
Thanks. Steve
Cold.
The easiet way I found was to make sure the tires are 30 all around in the garage and then just take them up 6 and 4 from whatever they are when I pull up to the track.
Old Sep 9, 2004 | 09:03 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Originally Posted by stuart
...incidentally you spelled the tire name correctly until 70000 corvette enthusiasts were looking...K-U-H-M-O :o not KUMHO
What? Kuhmo not Kumho? Now I gotta go change what is on the sides of my tire and my warranty sheet, too.
Old Sep 9, 2004 | 09:04 PM
cj99ytecoupe's Avatar
cj99ytecoupe
Default Wider RunFlats???
I am in the same boat you are in. I need some new rears but I also want some a little wider to improve traction problems. Does anyone make runflats wider than stock???
Old Sep 9, 2004 | 09:12 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Thanks much - I meant to ask that question. I ran my other tires on tracks at 35lbs all around, but I think your settings sound good.
I may try 36 all around (on the 18th at a NCCC event) to see how they perform. I also just installed new SS brake lines, and a new brake bias spring to try to neutralize the car's handling some. So far I really like the results from those - firmer brake pedal and less nose dive/weight transfer.
Plus, I just came from a club meeting and we're renting a road course in mid-October and I REALLY LIKE driving those (more than cones).
Again, thanks for the tip.
Old Sep 9, 2004 | 09:16 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Kumho does make a runflat, but they are hard to find right now. If you check www.Tirerack.com I think you'll see they are back ordered because they are very popular.
I debated going to a non-runflat for some time. I've had a compressor and tire patch kit for a while because I checked my tire pressures at tracks.
There is a risk going without a spare - but every Z06 made doesn't have spares, and has a compressor/repair kit without having runflats.
Old Sep 9, 2004 | 09:26 PM
MyOwn69's Avatar
MyOwn69
Hey, Cajun,
Remember, Bubba's waiting for you with his 56 Dodge Wrecker!!!!
Seriously, good luck!
Old Sep 9, 2004 | 09:30 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Originally Posted by MyOwn69
Hey, Cajun,
Don't wrecker drivers have to have at least five teeth to be Corvette qualified???????
Old Sep 9, 2004 | 09:36 PM
MyOwn69's Avatar
MyOwn69
Doesn't a toothpick and a "chaw" count as 2?
Old Sep 9, 2004 | 10:07 PM
StuzVette's Avatar
StuzVette
I was an inch of ordering the Nitto because they come in 285 35 18 and 305 35 18 however...the tread with is a bout 5-6/32's
I would have to go to NT555 to get 10+/32's ..
Do you happen to know the tread depth...on your tires...?
To Kumho ECSTA MX Installed
Old Sep 9, 2004 | 10:19 PM
Davesredvette's Avatar
Davesredvette
Right behind ya!!! Did you do anything funky with the shocks, like flip the brackets over to get more travel. I hear this helps get some shock travel back from a lowered car??
Looks great
Old Sep 9, 2004 | 10:35 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I'll find out for you. I know this series does not need to be shaved for racing purposes.
Old Sep 9, 2004 | 10:37 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Looks great
Thanks. Nope the shocks were a straight installation on my car which is lowered right at an inch all around on stock bolts. The Bilstein Sportshocks are somewhat shorter and I don't believe they would need any special treatment for lowered Vettes.
