Lowering question
Old Sep 10, 2004 | 02:36 PM
yellow01's Avatar
yellow01
Default Lowering question
Guys (and gals ) - I'm sorry to post another thread about something that has probably been covered millions of times, but I've searched and am simply confused about lowering options/possibilities
How much can the car be lowered just by turning the bolt with no cutting of any bushings? (any?)
How much by cutting bushings but using stock hardware?
When is aftermarket hardware required?
Many thanks!
Jon
Old Sep 10, 2004 | 03:27 PM
jrose7004's Avatar
jrose7004
I cut my back bushing about 2/3 and did not cut the front and I have 2 fingers from the top of the tires to the bottom of the fenders all the way around!
Old Sep 11, 2004 | 01:37 PM
FKING1's Avatar
FKING1
Lowering on stock hardware will give 3/4 to 1" frt or rear. Cutting 2/3 off front bushings will give up to 2 " or a little more. Don't cut rear bushings. If you want more that the stock 1" get longer rear bolts and lower as much as you want. I found that over 2" with F45 scrapes too much and bottoms out the shocks.
Fred K.
Old Sep 11, 2004 | 04:05 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Lowered right at 1" all around without cutting any bushings.
To Lowering question
By Michael S. Palmer | 2026-06-03 11:00:24
