question regarding the BlackWing air filter
Old Sep 13, 2004 | 06:25 PM
Antonio BananaS's Avatar
Antonio BananaS
Default question regarding the BlackWing air filter
do you use the stock airbox for this filter? any modification you need to make for the installation?
thanks in advance for all your input/s!
Old Sep 13, 2004 | 06:30 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
The Blackwing will allow for the complete removal of the stock airbox, and that baby will now breath...a half cover type piece is also made for those that want to hide the exposed filter element, most run it open. With this, you may want to also consider a hood seal molding!! Drive and enjoy.
Old Sep 13, 2004 | 06:32 PM
Cajun99's Avatar
Cajun99
What he said...
http://www.zip-products.com/Corvette...C1D2ABCC1B2C5C
Old Sep 13, 2004 | 06:47 PM
VetteSiNz's Avatar
VetteSiNz
Go for it....its easy as 1...2...3
Old Sep 13, 2004 | 06:57 PM
krabtree13's Avatar
krabtree13
simple and effective mod install...the best kind!!!
Old Sep 13, 2004 | 11:07 PM
mowton's Avatar
mowton
I understand the HP gains but what about the $260 for just a Filter? Am I missing something?
Old Sep 13, 2004 | 11:17 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Our only performance modification, and a good one!
Old Sep 13, 2004 | 11:25 PM
ACELR8N's Avatar
ACELR8N
Just did the Blackwing with a GHL Bullet exhaust and Magnaflow X-Pipe. Mucho bang for the buck. Really transforms the car. Did the hood seal and run the intake open. There is also a Halltech product that includes replacement of the Air Tunnel Bridge as well.
Old Sep 13, 2004 | 11:32 PM
jrose7004's Avatar
jrose7004
Exactly!
Old Sep 13, 2004 | 11:33 PM
Scratch's Avatar
Scratch
Yes you did miss something, or else I did...these are running about $210 I believe, unless there is a group special going on, may pick one up for less. You could also check the For Sale section here, may find a near new or used one for alot less. There are other set-ups available also that will produce as good results...now go get one!!
Old Sep 14, 2004 | 04:42 AM
TheDarkKnight's Avatar
TheDarkKnight
Yeah, a few things.
First, you won't need to replace it when it gets dirty. The monitor that comes with it will let you know when it needs cleaned. A nice chunk of HP. Exhaust sounds better. Engine seems to just ru better. Before I put it in, it kinda petered out near the rev limit. Immediately after, I accidentally bounced the limiter a few times as I found it kept going w/o losing any oomph. Assuming no change in driving style, you can also expect an extra 1-3MPG (my experience).
It is easy to put the stock one back on in case you need to for emmisions testing, something many of the alternatives can not say.
Oh yeah, and it friggin looks awesome.
To question regarding the BlackWing air filter
