Installed Blackwing**Check engine
Old Sep 15, 2004 | 08:58 PM
CarsRFun's Avatar
CarsRFun
Default Installed Blackwing**Check engine
Installed it went smooth, baby drove it for 40miles got on it a little for a few miles **makes things sound different in a good way ** anywho, went to a local pizza place, came out started the car and now have a check engine light on, everyone is attached correctly and what not?? Anyone else have this issue and how long will it take to Calibrate to my engine?
Jason
Old Sep 15, 2004 | 09:04 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I've heard several opinions on how long to retrain for the new airflow (100-200 miles). I hope someone can chime in with more specific numbers. As for your check engine light, did you reinstall the "gray pin" into your MAF sensor plug? I hope it didn't come loose.
Old Sep 15, 2004 | 09:08 PM
CarsRFun's Avatar
CarsRFun
yeah I plugged everything back in and rechecked to make sure nothing came loose, nothing had, i even turned the car off then back on see if it had cleared and its still on
Old Sep 15, 2004 | 09:11 PM
csexton's Avatar
csexton
Check all your connections and make sure you have a nice airtight fit!
Old Sep 15, 2004 | 09:13 PM
johninar's Avatar
johninar
You shouldn't have the check engine from the Blackwing. Something is not right with the install. Recheck (remove and reconnect the electrical connecters). Make sure the intake is tight.
Old Sep 15, 2004 | 10:20 PM
LiquidDI's Avatar
LiquidDI
Could just be you have something else wrong with the car. Get the code scanned at auto zone to find out what it is.
Old Sep 15, 2004 | 10:31 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Check the codes and tell us what comes up. That'll give you a better idea on what's the problem. While holding the option button, press fuel 4 times. For more info on how the codes work, use the search feature. Tell us what you find.
Old Sep 15, 2004 | 10:38 PM
dkdonkim's Avatar
dkdonkim
Jason
what's the code? i never had a problem after blackwing installed, but started getting some after headers with "modified" maf..
Old Sep 15, 2004 | 10:53 PM
Did not have any codes thrown with my Blackwing install. Recheck your hose connections to make sure they are air tight. Good luck.
Old Sep 15, 2004 | 11:06 PM
Blown2K's Avatar
Blown2K
I had codes pop up after my Blackwing install. It ended up being that the hose from the Blackwing to the throttle body had come off slightly. I tightened it and never had another code.
Old Sep 16, 2004 | 06:52 AM
CarsRFun's Avatar
CarsRFun
Default there were a ton of codes
U1088
U1160H
PO111HC
B1001H
U1000H
U1016H
U1096H
U1016H
P011S ?
P111HC
Please tell me these are not a prob!!
Old Sep 16, 2004 | 07:12 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
This can help....but it's still all "technical" to me...
http://97vette.com/howto/codes/index.html
"H" at the end means "Historical" and I believe "C" means "Current".
Old Sep 16, 2004 | 09:13 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
U1088
U1160H
PO111HC
B1001H
U1000H
U1016H
U1096H
U1016H
P011S ?
P111HC
The P0111HC is the code that causing the "check engine"light to come on, I can't access the code list from the computer that I'm currently using but here is the link that will show you what they mean and how to reset them Codes
Old Sep 16, 2004 | 09:31 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I just followed this link Service manual and couldn't find P0111 but I did find P1111 and P0112 which both relate to the IAT sensor, I didn't see what year car you had and if your IAT sensor is seperate from the MAF or not but you may want to check it out
Old Sep 16, 2004 | 10:57 AM
ae1m's Avatar
ae1m
Default C5 Codes
C5 Codes
Old Sep 16, 2004 | 11:45 AM
lvvette777's Avatar
lvvette777
I just ran the code check on my car I bought last week. Is it normal to have about 12 codes in history for a 2001????
Old Sep 16, 2004 | 04:44 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
As long as none of them are current, I can erase all of my codes then come back an hour later and have 3 or 4 show up for communication between modules
To Installed Blackwing**Check engine
Old Sep 16, 2004 | 06:25 PM
CarsRFun's Avatar
CarsRFun
cleared codes
disconnected bat
took everything off
reinstalled it
**my TB hose was almost off pushed that bad boy back up there**
started her up
NO CHECK ENGINE LIGHT
Yet
I will keep you all updated!
Old Sep 18, 2004 | 11:21 AM
CarsRFun's Avatar
CarsRFun
check engine light came back on today
time to buy a new car............... yeah right.
http://www.z06vette.com/forums/showthread.php?p=724201
possilbe oil on the MAF ill have to take it apart and clean it.
Old Sep 18, 2004 | 01:24 PM
MyVetteDream
Contact Evil-Twin. He may have a solution because he is one of THEE men, when it comes to this stuff. Good luck. BTW, I had heard of similar issues, but not with BW. I would think that once the oil gets into the system, it may take a while for the light to go out. Ask E-T. Good luck. Keep us posted.
